Keep SPORT Mode always engaged automatically?
eaqr70
Edgar
South Florida
2025 4Runner TRD Off- Road Premium
Quick question—does anyone know if there's a way to keep SPORT mode engaged automatically, the same way ECO mode stays on between drives? I'm trying to avoid having to manually activate it each time.
Hacksaw
az
2025 4runner TRD-ORP
I don't believe there's a way to do that from standard controls (maybe some OBD tool has a way to set it and override the default behavior).
I haven't used sport mode much. Would you mind describing what you like about it compared to other modes that would lead you to want it on 100% of the time?
eaqr70
eaqr70
Edgar
South Florida
Thanks for the info—that’s kind of what I figured, but I was hoping there was a hidden setting somewhere! I even checked using the CARISTA OBD tool, but no luck.
As for SPORT mode, I really enjoy the extra throttle response and tighter steering feel. It makes the car feel more alive and responsive, especially during highway merges or when passing other cars. I know it’s not great for fuel efficiency, but the driving experience is so much more engaging. If I could keep that feeling most of the time, I definitely would!
cama0303
MN
2025 Trailhunter
Are you able to change the engine noise from sport mode using Carista so its on for Normal/Eco mode?
Fishing
New York
The dealer might have access to alot more option to change than carista, which is limited right now.
FourRunner
GR Corolla Circuit Edition
My guess would be no. That’s the same situation in the Toyota GR Corolla. A high performance car that should be in sport by default resets to normal every time the vehicle is started. Except for when you are in Eco, then the GR Corolla also will start in Eco mode. Also good look getting the custom gauge setting to stay saved if you want the tire pressure gauge to be displayed under your custom gauge settings.
828findadventure
Tacoma & Tundra
My 4runner defaults to "normal mode" every drive. The "Sport Mode" adds a little more exhaust note, which I like. Watch your wheel spin in tow haul or sport, especially pulling out in traffic with wet roads from a dead stop.
it will stay in eco mode after ignition off if set to eco
it will stay in normal mode after ignition off if set to normal
all other modes have to be manually set after ignition off and the system will default to normal mode after ignition off if the mode is changed to anything but eco/normal after ignition on
OnePunchPan
Tristate area
My limited will stay in comfort mode or eco. If I use sport or sport+ it defaults back to normal
custom mode you can set the following :
1. trans shift points (holds gears longer), normal or sport or eco
2. shocks stiffens (if you have avs), normal or sport
3. you actually cant set the steering per se but it can either be normal or heavy depending on #1 setting
on our tundra i set custom to
1. trans shift points to sport (sport mode will set the steering to heavy)
2. shocks (normal)
OnePunchPan
Tristate area
Has anyone else noticed (for Limited or Platinum) that when you use "sport" for drivetrain in custom drive mode, it has a much rougher shift vs. the car in regular sports mode?
