Rumbling Noise from Rear of Vehicle
mars001
2003 4Runner SR5 4.7 V8
Isn't subwoofer non-directional? If it's coming from the subwoofer then you shouldn't be able to tell it's from the rear.
I’m also wondering if this could be related to the ANC system and whether it’s experiencing some kind of glitch. From what I understand, it uses microphones to detect cabin noise and then plays inverse sound waves through the speakers to cancel it out. The rumble I’m hearing is coming from the rear‑right area, which also happens to be where the factory subwoofer is located (for my case anyway since I have the JBL).
I don't have a Carista OBD2 module so I can't turn it off and verify it.
xp0nex
2025 4Runner ORP
Not entirely sure, as this is outside my limited understanding of how the system works. It was just a thought I had, and it seems other users have noticed something similar.
I took the vehicle out the other day and it was completely quiet—no rumbles or anything unusual.
raiderx11
Stephen
Seattle, WA
2025 Toyota 4Runner TRD Off Road I-Force Max Premium
I have the same exact noise coming from my 4Runner hybrid too. Sounds like it's coming from the back right side, just behind the back seat.
Things I can confirm after hearing it on multiple occasions:
  • It increases in volume when I go faster speeds.
  • The noise only happens when it's cold like about ~30 deg F...so I wonder if it has to do anything with the hybrid battery system.
xp0nex
2025 4Runner ORP
I just disabled ANC with Carista and will update if it resolves the issue.
xp0nex
2025 4Runner ORP
I haven’t heard the rumbling noise since I disabled ANC/ESE over a week ago. Not long enough to know for sure but so far so good.
Yes, since disabling ANC/ESE I have not heard the rumbling noise either.
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
Purchased Carista to disable the dreadful ESE fake engine noises and hopefully eliminate the rear rumbling noise by disabling ANC.
With ESE disabled, can finally hear what our ORP actually sounds like. Yay!
With ANC disabled, I believe the rumbling noise has stopped. Haven't driven much yet, so will keep an ear out for it.
BadTrainDriver
Powell, OH
Carista questions:
If I purchase the device through Amazon, then the subscription through Carista's website, is it instant that I have access to the paid features, or how does that work?
Can the Carista be shared, meaning can I set features in my car, then use it in another car to set features?
TIA for any help!
Carista questions:
TIA for any help!
Should be instant if you sign in with the same account info. I got the device from Amazon but got the subscription through Google Play because it was $30 for the entire year.
Yes, you can use the device on multiple cars, if they are supported. Found out my wife's Subaru isn't supported, which sucks, but the device has helped me enough with my 4Runner I don't care.
Enabled the windows to be rolled down with the fob, killed the engine noise and ANC, turned down my blinker volume, turned off seatbelt warnings in the rear, and changed my lane change blinker to 4 from 3 blinks.
BadTrainDriver
Powell, OH
Fantastic! Thank you for the info!
