Rear view digital mirror retrofit install?
charliemanse
DFW
2025 SR5 4X4
Power isnt the issue. It is the camera it uses that is the issue
ah gotcha. I think you'll need to manually route it. Stickerfab has a good video on it:
Slightly different question but along the lines of this post...what are your thoughts on a Wolfbox Tri-Pro bumper cam system versus what the ORP already has with the 360 cameras? I don't really care about recording. As I stated before I did not get the OEM digital mirror; I have the standard auto-dimming one. Seems like the Wolfbox is great, but not sure it gives enough more over my current setup other than seeing past my dogs in the back. If I recall the built-in cameras turn off over a slow speed, but I saw a post somewhere that said they could be left on for the off-road trims. Anyone know? Sorry if this is already stated somewhere, I did do a bit of searching but may have failed.
2025 4R Plat Heritage Blue , 2023 Tundra Plat Midnight Blue no-HV
the off road trims have the ability to use the camera's for trail riding and they have a specific button to enable full time use, but i am not sure at what speed cutoff it turns off?
its mostly for offroading speeds during technical parts of offroading where you are doing less than 25 mph
otherwise the other pano view shuts off after 10 mph and kicks in when you drop below 10 mph or was it 5 mph. cant remember.
