Pinging Sound when accelerating
kcos0320
Keith
Charlotte, NC
Has anyone else experienced a Pinging Sound when accelerating? So far, I have tried different grades of gasoline. I took it to the dealer and they couldn't reproduce the noise. Has anyone else experienced this type of noise?
drNick
Nick
Ft. Myers, FL
The reason I tried premium gas in mine. With it the engine purrs like a kitten.
dirtwheeler
United States
Nope. Does it only do it in motion, or does it also do it when you rev it up in park? Does it make the noise when it cold, warmed up, or both? Just curious.
i wonder if he is hearing the toyota injector tick?
toyota has a very distinctive high pressure fuel injector tick, its normal across all BoF vehicles.
i normally dont hear it on non BoF vehicles like camry, and other like it.
but i am so use to it, i get worried when i dont hear it.
and it gets worse in winter time until the engine bay warms up :)
it probably is worse on the 25 4R since they got rid of the sound deadening on the hood on the lower trims.
high pressure fuel pump is noisy, all 8 injectors are noisy
never heard a ping or knock on mine in any mode or throttle input
87 octane pump gas. thing is smooooooooth
Jakethewhippet1
Geneva, IL
2025 4Runner Off Road Premium
No pinging with my ORP. The noise you're hearing is probably just direct injector noise. Actual pinging from too low of an octane typically happens when the engine is under heavy loads like racing or heavy towing up steep hills. Take it to the dealer and they can diagnose for you.
Moby
Moby
NJ
TRD OR Premium
I think i did once few days ago and tried to look/ hear it again if it happened again. But nothing somfingers crossed.
btw, in my previous with other brands, dealer services guys will not do anything meaningful. They will probabky say to that they can’t diagnose it and try using premium gas. I used regular gas but from brand gas pumps only only like shell bp exxon. Good luck.
kcos0320
Keith
Charlotte, NC
Yes, the noise I have been hearing was the Direct Injection noise. Older 4Runners had power injection, which is much quieter.
early toyota's had only D-4 systems (direct injection in 1996) but then switch to the better D-4S systems (direct/port injection) starting around the 2010's with most phased out by late 2010's.
port injection for low speed efficiency vs direct injection for higher power at high loads
