squawbum
Joe
Marin County
Yeah, I understand. My remote worked all of about 15 seconds. I did have the light installed and can’t get to the clutch or hard wire the remote without removing the grille entirely. I don’t know yet if it’s a short or if it’s the remote of the Warn winch. They are apparently notorious for going bad. We will get it squared away though. There’s a way to relocate the control box under the hood or mount in front of the radiator, so it looks like that will be my next mod. 🙄
Do yourself a favor and order a pack of those plastic button fasteners. I’ve already lost two of those just trying to figure out how I am going to make all of this work.
haha. Already lost one myself. Good luck with your troubleshooting and fix. Let me know what you do.
Roam4Free
Ronnie
NC
25 4R TRD Pro
Great job, looks awesome. I love the lighting choices, seen your YT a few times. Hopefully you changed the OEM horn while you had it all opened. Many articles on the premium horn install if needed. Be safe!
papadop88
papadop88
Los Angeles
2025 4Runner TRD Pro
Cut off the hideous muffler dong. Took about 30 mins to cut it the way I wanted it and sand/buff it smooth. Cut off about 14". Can't see it anymore and it cleans up the back very nicely.
Before...
2025 4runner 6th gen Papadop88's Underground 2025 4Runner TRD Pro 6th Gen Build IMG_0100
After:
2025 4runner 6th gen Papadop88's Underground 2025 4Runner TRD Pro 6th Gen Build IMG_0103
Some more pics:
2025 4runner 6th gen Papadop88's Underground 2025 4Runner TRD Pro 6th Gen Build IMG_0101
2025 4runner 6th gen Papadop88's Underground 2025 4Runner TRD Pro 6th Gen Build IMG_0102
2025 4runner 6th gen Papadop88's Underground 2025 4Runner TRD Pro 6th Gen Build IMG_0104
2025 4runner 6th gen Papadop88's Underground 2025 4Runner TRD Pro 6th Gen Build IMG_0105
2025 4runner 6th gen Papadop88's Underground 2025 4Runner TRD Pro 6th Gen Build IMG_0106
2025 4runner 6th gen Papadop88's Underground 2025 4Runner TRD Pro 6th Gen Build IMG_0107
2025 4runner 6th gen Papadop88's Underground 2025 4Runner TRD Pro 6th Gen Build IMG_0108
BillyG4Runner6G
Billy
Delaware
popadob88,
Some of us on the forum have noticed some vibrations at 70+ mph with the factory Toyo tires.
https://www.4runner6g.com/forum/threads/can’t-fix-trd-pro-steering-wheel-vibration.5336/
Just wondering if you have experienced any vibration or shaking at highway speed now that you are running the 295/70R18 Nitto Recon Grapplers?
I are thinking it maybe the cheaper TOYO OPEN COUNTRY A/T III GA
tires they are installing at the factory that are not balancing or balanced correctly.
papadop88
papadop88
Los Angeles
popadob88,
As of 1000 miles on them, I have zero vibrations on the Recons. The stock AT3s in SL load shouldn't be vibrating either. Nitto/Toyo are known to balance very well with minimal weights, hence why I only run Toyos and Nittos on my trucks.
I used to love BFG KO2s but they recently became impossible to balance, so I switched to the Toyo RT Trails and now the Recons and have had zero issues.
The stock AT3s may not have been mounted properly. Unfortunately, many tire installers have no idea that tire manufacturers add a yellow/red/or any other color dot on the tire to signify where that dot should be mounted on the wheel. Those dots do in fact need to align with the valve stem. This helps minimize needed weights for balancing, etc, and leads to minimal vibrations, if any. It's sad many tire installers don't know this.
First thing I'd do is see if you have those dots on your stock AT3s and see where they're mounted in conjunction with the valve stem. If they're aligned, maybe you just need to rebalance a bit. If they're not, try that first. The stock AT3 in SL load are super light (43 lbs) so balancing shouldn't be a major issue.
Good luck!
BillyG4Runner6G
Billy
Delaware
Good luck!
Great information and good to know. Thanks I will check it out.
papadop88
papadop88
Los Angeles
Thank you. I'm in a unique situation so I honestly don't know how much the bill actually is on the mods, but I would estimate around $11K with parts and labor included.
I've been going back n forth on color matching, but I am sticking with the black fenders. I actually like the contrast they provide and give off a wider stance (optical illusion). It's why the designers did it this way... ;)
BillyG4Runner6G
Billy
Delaware
Looks great and thanks for the video. Somehting else I have to get now! 😅
papadop88
papadop88
Los Angeles
So, the day has finally arrived. I was one of the first, if not the first to pre-order the Westcott Designs collar lift kit months ago and they finally arrived. So for those of you who ordered this kit for the Pros, they should be shipping out to you soon.
Here was the issue. When WD was R&Ding these for the Pros and Trailhunters they realized the bolts on the stock top hats weren't long enough once you put the collar on, so they went back to the drawing board. Not sure why Toyota did that with the 4Runners when the Tacomas clearly didn't have the same issue. Nonetheless, WD designed and built these 1" top hats out of billet to get these collar lifts to work.
The top hats arrived today. The rest of the lift kit comes on Tuesday. Here's a couple pics of the top hats. They seem to be extremely overbuilt and solid. Beautiful design and anodizing, per the usual from Westcott Designs.
2025 4runner 6th gen Papadop88's Underground 2025 4Runner TRD Pro 6th Gen Build IMG_0307 Larg
2025 4runner 6th gen Papadop88's Underground 2025 4Runner TRD Pro 6th Gen Build IMG_0308 Larg
