Light switch panel-beginner question
ThatSickRIp
TSR
2026 4Runner SR5
Im looking to get a 4 or 6 gang light switch panel, I only want a few lights as of now-ditch lights, possibly rear lights on the roof rack, maybe Raptor lights, etc.
Do you have to run a fuse tap? I understand the risk of leaving lights on and draining the battery, but I see that as low risk since the switch panels, as well as the light, will be on and noticeable. Are there more important reasons to run the fuse tap?
MARK4A3
Kitsap County, WA
26 4Runner ORP Hybrid
I actually have an S-tech 6gang switch panel system out of my old Tacoma if you’re interested.
The main box contains fuses and common relays. This is helpful since S-tech closed business in the past year.
To answer your question, this system will have a fuse tap on the accessory. This means the switch panel will only work when vehicle is in ACC/running
I got this Bumbee 8-gang switch panel for less than $80 on Amazon. It looks just like most other one for less. Wiring was very easy. I put it on the left fuse box (by battery/gas-model), and run the wire into the cabin. I put the controller on the left side below the vent, with double-side automotive 3M tape. Been great with no issue. I wired to my Baja Designs 2.0 Squadron Sport ditch lights.
This specific switch has an internal switch where you can choose between battery power (recommended) or ACC power (on/off with car). I skipped the wire to ACC fuse. With battery power, you can turn lights on/off whenever, even when car off.
2025 2026 4runner 6th gen Light switch panel-beginner question 20260914_215154
2025 2026 4runner 6th gen Light switch panel-beginner question 20260917_073633
2025 2026 4runner 6th gen Light switch panel-beginner question 20260915_000426
2025 2026 4runner 6th gen Light switch panel-beginner question 20260918_140933
2025 2026 4runner 6th gen Light switch panel-beginner question 20260916_091146
ThatSickRIp
TSR
2026 4Runner SR5
Thanks, this is exactly what Im looking for! The few lights I want, I want to work when chilling at the beach in the evening and want light without the accessory on
MARK4A3
Kitsap County, WA
On the old truck I ended up wiring the ditch lights separately. Ended up being super useful that way.
T_Pomp
Anthony
Illinois
2025 TRD Off Road Premium
Use an AuxBeam or similar panel. It will make things a lot easier. I would get an 8-switch panel if not larger. I installed an 8 and wish I had gone bigger, lucklily I have the prewired AUX switches installed.
ThatSickRIp
TSR
2026 4Runner SR5
I had thought about this as well. I was thinking of just getting the CaliRaised ditch light kit that comes with the switch, I pop a blank on the factory panel and wire it there.
Still might go that route since I have so much Milwaukee lighting that they can easily supplement a few trips a year for the back of the 4R and the ditch lights up front
I probably need to do it before Black Friday so I dont end up buying a ton of stuff because it was "on sale" 😂
T_Pomp
Anthony
Illinois
I had though about this as well. I was thinking of just getting the CaliRaised ditch light kit that comes with the switch, I pop a blank on the factory panel and wire it there.
Sorry to butt in here, but I would plan ahead and have the availability to wire in "future" lights that you might not know you want yet.
ThatSickRIp
TSR
2026 4Runner SR5
Not butting in at all, its a discussion forum 🍻
But you are enabling spending and mods 😂
That was my other thought, have it there and ready for future lights as needs change.
This site is getting expensive to be on 😅
T_Pomp
Anthony
Illinois
Look at it as "less of a future headache for future upgrades". :sneaky:
