Island4Runner
Mikko
British Columbia > Vancouver Island > Victoria
2026 4Runner Platinum, 1995 4Runner, 2003 BMW 745i Sport, 1991 BMW 535i
It's in the back, and there's space for the equipment in a cubby in front of the hybrid battery. Wiring will probably be the easiest I've ever done lol
No idea what size the 12v battery is though.
I’m looking at that cubby in front of the battery… Already cut a piece of ABS for a rack… it’s 9-inches wide by 42.5 inches long, and maybe 4 or 5 inches high. Those AudioControl Epic Series amps are only less than 7 inches wide, by around 10 or 11 inches long. They’d fit well.
Dead Horse
Oklahoma
I haven't picked everything out yet...not until I know what I can add.
I may just use the Kicker Key 500.1 on a sub and call it a day. I'd rather not pay for a whole ass DSP for a small system.
Island4Runner
Mikko
Seems the Trailhunter and PRO may have a starting battery up front under the hood, drivers side. Any able to confirm?
From Google Ai:
“The 12-volt starting battery for the 2025 Toyota 4Runner TRD Pro (which features the i-FORCE MAX hybrid powertrain) requires a Type C (LN4) size battery rated at 75Ah (20-hour rate) or greater and 776 Cold Cranking Amps (CCA) or greater.
Battery Specifications
    • Group Size / Type: Type C (LN4 / BCI Group 94R equivalent dimensions)
    • Cold Cranking Amps (CCA): 776 CCA minimum
    • Capacity: 75Ah (20HR) or greater
    • Note: Stop & Start and hybrid accessory-managed models require OEM or Toyota-approved replacement batteries to properly interface with the vehicle's electrical and charging systems.”
josiahg52
Josiah
Maine, United States
From Google Ai:
Battle of the AIs! I love people who use AI for information sourcing without a actually looking at the source the AI uses. AI are often wrong.
From ChatGPT;
"That Google AI result appears to be conflating the non-hybrid 4Runner with the i-FORCE MAX. The 2025–2026 4Runner i-FORCE MAX does not have its 12-volt battery under the hood on the driver's side; the 12-volt auxiliary battery is located in the left/driver-side rear cargo area, behind the interior trim near the rear wheel well. This has been physically documented on i-FORCE MAX 4Runners.
That error also makes the claimed LN4/75 Ah/776 CCA specification suspect as an i-FORCE MAX specification. Those figures do appear in 4Runner battery documentation, but simply attaching them to the TRD Pro/i-FORCE MAX is not justified when the same answer demonstrably gives the wrong battery location. Toyota even publishes a separate 4Runner HV owner's manual for the hybrid model.
So the Google result should not be relied upon to identify the i-FORCE MAX battery. The hybrid-specific Toyota documentation or the label/part number on the actual rear-mounted auxiliary battery needs to be used to establish its correct size, capacity, chemistry and rating."
NOTE: I didn't verify the ChatGPT response, but I can confirm my Trailhunter's one and only 12v battery is in back, left side, behind a removable trim panel.
Island4Runner
Mikko
Yes AI is often wrong, especially on a newer model when there are 9 variants to the 4Runner there could be nuances. I thought having it underhood could be possible because of the alternator being close by, so an up front location would be sensible.
Since the alternator is an optional item on the ORP, I wonder if there is a factory kit with all the parts/harnesses etc?
Dead Horse
Oklahoma
There are a couple of threads about it (adding Aux switches/alt), but no resolution if memory serves. I've looked at the wiring harnesses in the service manuals, and there's an entire section that's NOT present if you don't have the Aux switches and alternator. I may be thinking of the harness that powered the factory light bar though...That's what I was sussing out the wiring on (I bought a Trailhunter light bar and tore it apart to make it work without the factory wiring LOL).
josiahg52
Josiah
I thought the alternator was added if the auxiliary switches were added. I shopped for the ORP and I don't remember seeing "add alternator" option, but I know they change options throughout the production year.
Dead Horse
Oklahoma
Yeah, the ONLY way to have an alternator on the hybrids is to have the aux switches. Standard on Pro/Trailhunter and optional on ORP. Pretty sure that's for 25 and 26. And thanks to Toyota's US distribution system, completely unavailable as an option in entire regions. Like Gulf States Toyota doesn't (or didn't, haven't checked recently) have ANY ORPs with the Aux Switches. I specifically bought outside of GST (where I live) for this exact reason. I wanted an alternator.
Interestingly, the Tacoma hybrids with the aux switches don't have alternators as a rule. The Trailhunter and Pro do, but I've seen lower trimmed OR/ORP with aux switches and without alt. From what I can tell, the Pro/Trailhunters have four aux switches, while the lower trims have three.
Toyota, you so crazy.
Dead Horse
Oklahoma
Interesting on the Tacos...Trailhunters and Pros have four aux switches, and the ORs only have three. I bet that 4th is a high-amp one and that's why they get the alt.
This aside has been brought to you by LIMU EMU, your most hated advertisement on Hulu this week.
Now back to your regularly scheduled DSP JBL discussion on the 4Runner and not Tacomas.
josiahg52
Josiah
Yes, I wanted an ORP with options, but the standard Trailhunter ended up being the easier get and had what I wanted.
