828findadventure
Tacoma & Tundra
Updated with complete DIY video:
I bought the front camera from Beat Sonic. I have begun the install, but the weather is not helping. All I need to do is remove the front bumper and the mechanical louvers inside the grille so I can mount the camera properly. So here are some notes and screenshots, and I will make a video of everything the best I can.
After the head unit is removed, one panel and four 10mm bolts, the harness is all plug and play, with only a few panels needing removal with a small plastic pry tool. I used a snake to run the camera wire behind the dash towards the passenger side, and from the engine bay on the passenger side. There is a quarter size grommet that is easy to remove and reinstall to run the camera wire that has a black and red power/ground with an inline fuse. I ran that camera wire starting in the engine bay and snaking it through to the passenger floor board, and ran the wire up to the head unit. It was very easy. The red and black wires I just prepped with a black webbed sheath and shrink tubing and ran to the battery. This setup will require power and ground for the camera. I have tested it, and everything works, just waiting for time and warm weather to remove the front bumper and complete the mod.
I am going to mount the camera at the top of the top since I have the Heritage grille that has a place for it. To activate the camera, you have the vehicle in drive and press the button once, and the camera activates. There are several programmable functions that I have not explored yet, but I will try to.
https://www.beatsonicusa.com/products/cs15?variant=46414827913367
2025 4runner 6th gen Front Camera (Beat-Sonic) install in grille on 6th gen 4Runner SR5 - DIY Screenshot 2026-02-12 at 11.44.10 AM copy
2025 4runner 6th gen Front Camera (Beat-Sonic) install in grille on 6th gen 4Runner SR5 - DIY Screenshot 2026-02-12 at 11.44.32 AM
2025 4runner 6th gen Front Camera (Beat-Sonic) install in grille on 6th gen 4Runner SR5 - DIY Screenshot 2026-02-12 at 11.47.21 AM
2025 4runner 6th gen Front Camera (Beat-Sonic) install in grille on 6th gen 4Runner SR5 - DIY Screenshot 2026-02-12 at 11.45.38 AM
2025 4runner 6th gen Front Camera (Beat-Sonic) install in grille on 6th gen 4Runner SR5 - DIY Screenshot 2026-02-12 at 11.45.26 AM
chasedstream641
wow! i always get so disappointed when i see something i like but when i click the link its 999$ and i cant justify the price but this is actually very affordable (even if i only use it <100 times over the next 20 years)!
BonRunner
2026 TRD Sport Premium / WCP
What is the use case for this? Can a dash cam accomplish the same thing?
828findadventure
828findadventure
Tacoma & Tundra
This is to either view your approach angle to an obstacle or when you are pulling up to an object like a car. I will use it in diagonal parking spaces in the parking garage I use for work, because it is hard to judge how close I am getting to the concrete.
Sween77
mike
KY
If possible send us some images that the beat sonic creates .
828findadventure
828findadventure
Tacoma & Tundra
I haven't seen Beat Sonic do anything with the camera other than have it on their website. I just went for it, and the instructions with the harness are great.
828findadventure
828findadventure
Tacoma & Tundra
Following this. Beatsonic link says camera sold separately? Which one did you get?
@828findadventure
I got the front grille universal mount one in black, but I am mounting it in the grille hole made for cameras. Pictures and video to come soon. The others only come in white. Note: I tried some cheaper cameras from Amazon and could not get them to work.
828findadventure
828findadventure
Tacoma & Tundra
828findadventure
828findadventure
Tacoma & Tundra
OK, finally finished the front grille camera install on my 25 4Runner SR5. I'm not a fan of the front camera style and will be doing something about that eventually, but it all works great and was an easy install.
