Filling gas shuts off with 2-3 gal additional
josiahg52
Josiah
Maine, United States
I'd rather not risk the vapor-recovery/evaporative-emissions system.
Adding more fuel can force liquid gasoline into the charcoal canister and vapor lines, which are meant for fuel vapor—not liquid. That can cause:
  • Fuel spills or expansion overflow, especially in heat
  • Gasoline odors and emissions
  • A check-engine light or damaged EVAP components
  • In some cases, poorer refueling behavior later
The simplest rule: stop at the first automatic shutoff.
You're not avoiding risk, you're just not filling your tank.
What if you go to another station with a different nozzle and you get another one or two gallons in before the first automatic stop? What if you only put five gallons in and it stops? That's it then? You drive away with half a tank of fuel?
You're method isn't conservative or safe. It's excessively risk averse.
  • Like
Reactions: L-2
wickncsu
Wick
Kure Beach NC
Generally advise against topping off. 3 gallons sounds… unusual though. Are you sure it behaves this way at all pumps?
Yes, some at slow delivery are faster than others which I guess increases foaming leading to the early shutoff.
LostInAZ
Carlos
2026 Toyota 4Runner ORP
I did the "wait till the fuel light comes on test" and I also got about 16.8gals till first pump shut off. So does that mean that the tank still has about 2gals left of fuel or does that mean that the tank was NOT fully filled when the pump shut off? I guess the real test is to try a full tank and just drive till the engine shuts off and then refill and see how much you can fill it with. Any volunteers?
sjm.esem
Stephen
ONTARIO CANADA
2027 Toyota Land Cruiser, 2020 Polaris Slingshot SL Autodrive, 2004 Honda GL1800
well if you ruin your evap canister thats about a $600 part. so is it worth the extra $10 of gas you are able to get in worth that cost? and thats the cheap part of the evap system if i remember correctly.
someone with better knowledge can probably correct me.
its also know as the charcoal canister and over filling will pour gas into it and ruin the charcoal activator if i remember correctly.
I would day that the engineers should try and do a better job on the filler design then. Sounds kinda dumb that you can destroy your evap system, by putting in fuel.
josiahg52
Josiah
That sounds normal, about two gallons reserve.
I don't advocate filling the tank of any gas vehicle to the brim due to the known issues it can cause. I also think blindly filling only to the first auto shutoff is not always going to effective, but it's the no thought required method. I don't have a 4Runner yet so I guess I shouldn't criticize any one doing what they do. I just compare it to my other vehicles where I've tracked every mile, every gallon I've put in there: almost 90k on one, 140k on another, and 75k on my truck. I generally know within 0.5 gallons how much will go in each tank depending on where the needle is on each gauge, if the low fuel/reserve or low range (where equipped) warning is on and how far I've driven since then. That's not because I'm smart, it's because I have data I can use. I plan to do the same with the 4Runner.
isnt part of the evap system is to catch and neutralize gas fumes ? where do you expect them to put the canister to catch those fumes? you can only put it so high above the actual gas to catch them?
but if the owner is constantly filling that neck feeding to the tank up past the evap canister opening that the engineer thought was high enough to ensure you dont feed fuel into the canister if you dont over fill fuel system hardware.
i mean i have seen people fill the neck to the point where you can actually see fuel in the filler port.
and i am guily of doing that years ago back in the 2000's but stopped doing it.
josiahg52
Josiah
The purpose is to recover fuel vapor and burn them off with normal engine combustion. The system uses tubing/piping, solenoid valves, check valves, and engine vacuum to draw the fuel vapor into the engine air intake. Damage is caused by overfilling with fuel, not a bad design.
speedyssss
steve
so cal
2026 4runner trd pro
Just broke 1000 miles on my pro this week. Filled up yesterday coming back from Mammoth. I had about 30 miles left and truck only took 15 gallons of gas. Part of me was glad thinking wow only 75$ of gas to fill my tank at almost empty... then I started to think why did it only take 15 gallons. When I only get 15-16 mpg and extra gallon or two makes a difference in stops on longer drives.
josiahg52
Josiah
What did the fuel gauge indicate? I'm not saying it needs to be buried, but it should at least indicate full, no, if the manual instructions are blindly followed?
speedyssss
steve
so cal
Honestly I dont recall where fuel gauge was at. I was only looking at how many miles the truck said I had which was about 30ish. The light was not on yet. But when I left the gas station the gauge was at full. Miles left was about 280. Ai says we have about a 19 gallon tank and the low fuel light doesnt come on until about 2.8 gallons left. So we are only talking about a gallon of gas variable since the fill up was 15 gallons. Main thing is we all wish Toyota put a slightly larger fuel tank in these trucks.
mfoga
Socal
r4unner
I saw something similar today. I had lil Less than 1/4 tank and it’s took like 12 gallons and showed full and showed range of just under 300 miles. I wonder if that is part of the reason file mileage if what it says it’s it that it’s not accurate in determining how much gas is left. I think next fuel up I’ll reset a odometer and measure how many miles based on much gas I add after the next fill up
Seems weird Ian suddenly down in mid 17s for mpg based on display.
sha66y
Rhode Island, USA
2026 4Runner, 2011 FJ Cruiser (NSSE)
No one is saying they want to fill it to the neck. But maxing-out at 17 gallons in a 19 gallon tank is ~10.5% less potential gas and that seems odd.
josiahg52
Josiah
But you're never (probably very rarely) filling anything near a truly empty tank. If people are expecting 19 gallons to go in every time, that's not a reasonable expectation. I was under the impression that people were observing a tank that wasn't nearly indicating full after the pump first automatically stops, but more and more, I think people are expecting 19 gallons on the pump every time.
https://www.4runner6g.com/forum/thr...s-illuminated-and-fuel-vehicle-message.11538/
sha66y
Rhode Island, USA
True, the remaining mileage number which indicates I've nearly run the tank dry might not be representing the actual amount of fuel left in the tank. But this raises another - different concern of being able to rely on the remaining mileage indicator. I guess it's just the age we're in, where the interface seem to know more than they're willing to accurately share. As a UX designer this drives me crazy.
