- First Name
- Josiah
- Joined
- Jun 6, 2026
- Threads
- 1
- Messages
- 209
- Reaction score
- 101
- Location
- Maine, United States
- Vehicle(s)
- 2026 Trailhunter, 2018 Ram 2500, 2001 BMW M5, 2001 BMW X5 35d
I'd rather not risk the vapor-recovery/evaporative-emissions system.
Adding more fuel can force liquid gasoline into the charcoal canister and vapor lines, which are meant for fuel vapor—not liquid. That can cause:
The simplest rule: stop at the first automatic shutoff.
- Fuel spills or expansion overflow, especially in heat
- Gasoline odors and emissions
- A check-engine light or damaged EVAP components
- In some cases, poorer refueling behavior later
You're not avoiding risk, you're just not filling your tank.
What if you go to another station with a different nozzle and you get another one or two gallons in before the first automatic stop? What if you only put five gallons in and it stops? That's it then? You drive away with half a tank of fuel?
You're method isn't conservative or safe. It's excessively risk averse.
