Ditch Lights recommendations?
KevinH
Kevin
Tampa
Escalade soon to be 4runner
What are some good sites for Ditch lights? I seen caliraised, diode dynamics, and the don’t like the Baja ones. Are there any other sites someone can recommend? Thanks
KD2MYW
Phil
NYC
I may know the least but I can say I just installed a set. I used Rigid Industries with CaliRaised brackets.
2025 2026 4runner 6th gen Ditch Lights recommendations? IMG_1481
mfoga
Socal
r4unner
Honestly I was told by a buddy who access to a lot of these big name brands at a discount he would still just buy Amazon stuff if it's just an off road light. Most last as long may not be quite as bright but plenty bright and way cheaper. If it's something used on my the road and needs sae certifications to be legal then the big brands are the way to go.
KD2MYW
Phil
NYC
My original plan was to get the CaliRasied Bracket Kit with the lights. I switched last minute but still used their brackets and antenna mount off the lights. The CaliRaised kit is probably the best bang for the buck!
just be mindful, make sure (if you get them) your hood struts are compatible with your ditch light mounts.
they tend to use the same mount location
Bernie
2018 Mercedes AMG GTc
I went with Rigid on Wescott brackets. I’m happy.
2025 2026 4runner 6th gen Ditch Lights recommendations? IMG_1743
ysv85
Yessi
2026 Toyota 4Runner TRD ORP
I went with Diode Dynamics ditch light set
2025 Big Red
Ron
4 Runner 2025
I went with CaliRaise. The most complete kit, brackets, lights, wire harness and switch fit in blank on dash. I choice because wire harness and wiring is a breeze. I also have hood struts. Fits no problem.
Timmybung
Timothy
NH
Diode Dynamics. Wiring is top-notch on their products.
Timmybung
Timothy
NH
Yea I keep coming back to that one.
I've installed their ditch lights, backup lights, and hitch pod backup light and on all of them the wiring was excellent quality / easiest integration I've ever done.
KevinH
Kevin
Tampa
Did you hook the ditch lights to the oem switches
