- First Name
- James
- Joined
- Nov 10, 2024
- Threads
- 15
- Messages
- 243
- Reaction score
- 277
- Location
- st simons island
- Vehicle(s)
- rav4, audi tt , 75 ford bronco
Respect!
I had considered going with something like that as well but I don't have the skill set. I can get you the dimensions and elevations of the bolt holes to save you the time and effort of figuring those out. It was pain in the ass due to the cramped space. I went through 3 low quality prints until I had the elevations right.Man, now you have me going down the compressor rabbit hole. Looks like that compressor is about $350 for the kit (if I'm looking at the right one on ARB website). And I can make a mount for that spot easy enough. I don't have access to that good of a 3D printer but I have a plasma table and a press brake so I can make one out of formed steel plate no problem.![]()
That would be great. ThanksI had considered going with something like that as well but I don't have the skill set. I can get you the dimensions and elevations of the bolt holes to save you the time and effort of figuring those out. It was pain in the ass due to the cramped space. I went through 3 low quality prints until I had the elevations right.
Thank you! It was a fun project. I need to do an update to the post with how I finished the install. I tore apart the ARB factory wiring harness to get rid of all the extraneous wiring for lockers etc and ran that into a CH4x4 switch in an aux location.Great Job! I've been looking everywhere for a mount since I got my 4Runner. I took the ARB out of my Jeep when I traded her in. How are you running the wiring for it? My plan was to run the switch wire to one of the factory AUX switches but I will need to run the power to the battery.
[/QUOTE
Thank you I had a lot of fun doing it and I am glad you're taking advantage of it. I realized that I had saved it in thousands when I went to print it myself and forgot to update the STL file.AMAZING writeup, and as an engineer with 3D print experience, super helpful to have an STL file to work with.
One thing I will say, the STL file has dimensions in the *thousands* of millimeters (15,000mm = 1500cm) and the model ended up being gigantic. Not a problem as I can just scale it down 1000x in Inventor, but worth a note!
oh awesome! I just got the same air compressor. think you could print me one!? Obviously I’ll payUpdate: STL file added for download:
https://www.4runner6g.com/forum/att....13221/?hash=271aad3d31c914d048f25eb42f337651
I found a suitable location in the engine compartment to mount my ARB Single Motor Air Compressor just didn't have a good way to mount it. The local maker's space at the college has an incredible 3D printing lab so I decided to model something myself. I feel like it turned out decent for my first foray into 3D printing. I started out on solid works but jumped over to Shapr3D as solid works is just not that intuitive.
This is an awesome model. Saved it for later use as I am going to look at new 4Runners tomorrow.Thank you I had a lot of fun doing it and I am glad you're taking advantage of it. I realized that I had saved it in thousands when I went to print it myself and forgot to update the STL file.
