0 degree sliders from Reckless Off Road Fabrication
Flyfisher
Allen
5th Gen 4Runner
After reviewing several rock slider brands, I purchased a set of "0" degree sliders from Boris at Reckless Off Road Fabrication in So. Cal. I purchased these because I was able to order them in "0" degree angle and the fact that they are installed using beefy 5/8" bolts that go through the frame, vs using riv nuts or similar hardware, making for a very sturdy slider. I had to make a trip to So Cal for some other business and had them installed at their facility. Installation was fast and Boris was very accommodating.
2025 2026 4runner 6th gen 0 degree sliders from Reckless Off Road Fabrication IMG_1608
2025 2026 4runner 6th gen 0 degree sliders from Reckless Off Road Fabrication IMG_1609
I'd be too worried about something popping up and getting caught and torqued in those blanks spaces. My wife would appreciate a real step though but for now she found a way to use the factory rock sliders.
Flyfisher
Flyfisher
Allen
5th Gen 4Runner
then these are not for you.
Do you have the stock side steps?
Yeah, just the sliders on the Trailhunter. Wife has a small foot, so they work for her. I am 6'6", so assistance getting in not required.
Well if you have sliders they are mounted underneath and have the same opportunity to get caught up on something as these.
I tend to agree, those big gaps are a prime opportunity for a stick to push up between that and your panel. Downed limbs with multiple branches have a tendency to roll as you crossover them and can twist one or more branches up into that space and cause significant damage.
Not knocking the sliders, they look plenty stoudt and have good form, just something I'd be considering when using them off road.
Vincenzo
Southeast
I’m assuming you have skid plates
Vincenzo
Southeast
I’m assuming you have skid plates?
ffs ...if the owner is driving over logs, limbs, and debris, then they can go slow and
work on not popping one up w/o stopping and checking and damaging things.
otherwise...I've been all over this planet and logs and big sticks just are not a problem
on roads and trails unless you see them and decide to drive over them. and stick and small trees that will pop up are very rare on used trails to be honest, unless you are going on
unused tote roads. your CV boots are the most susceptible things on the vehicle
if you go through storm or tornado damage anything can happen but what percentage
of driving is gonna expose you to that ?
But all sliders are mounted and have something that can be caught on. The entire vehicle has things sticks can be caught on. This isnt any different. It isnt a concern.
Not sure where you off roading without debris across the trail but I guess if your off roading in an open field your right, otherwise, not so much.
As far CV joints, that's what the A Arm skids help with, I even went with the Slee crossmeber to prevent sticks jamming into my radiator.
JMHE
That's why if your going through any kind of woods you get top plates.
