CAMTuning
Cam
NM
2025 Tacoma TRD OffRoad
Knock • Fuel • Boost • Torque — Learn the Language of Power
This is a Tuning Fact series designed to open up the hood on how your Toyota actually thinks. Each post breaks down real parameters and real log examples so you can make sense of available data, and understand the importance of having a way to access it.
This isn’t about scare tactics or shaming off-the-shelf maps—it's about awareness. When you understand what “healthy” looks like in a log, you gain control. You stop guessing (you don't know what you can't see). You start catching issues early and get the most from your mods and tune.
Discussion is encouraged. Bring your questions, bring your curiosity. If you want power, reliability, and consistency, it helps to know what your ECU is asking for—and what it’s actually getting. That’s where tuning stops being a mystery and starts being a tool.
CAMTuning
CAMTuning
Cam
NM
Session 1:
What “-3.0° Knock Correction Angle” Actually Means (And Why It Isn’t Bad)
Most people are used to thinking that any knock number = danger.
On the new 2.4T Tacoma / 4Runner, that’s not actually true.
The Short Version
On this platform, -3.0° of Knock Correction Angle (KCA) = the baseline.
It’s not knock. It’s not a problem. It’s not timing being removed.
It’s the ECU’s neutral position — the engine’s “zero.”
Think of -3.0° as the truck saying:
“We’re good. This is where I start making decisions.”
When KCA Moves More Positive (like -2, -1, 0)
The ECU is:
  • Adding timing
  • Seeing clean, stable combustion
  • Responding to good fuel quality
  • Essentially rewarding you
This is what good 91/93 octane should look like on a healthy tune.
When KCA Moves More Negative (like -5 to -10)
The ECU is:
  • Removing timing
  • Hearing noise/instability it doesn’t like
Possible causes:
  • Lower quality fuel / 87 octane
  • Heat-soaked intake temps
  • Too much boost for current conditions
  • Tune or mechanical issue
Note: Some timing pull during shifts is normal — don’t panic.
This doesn’t automatically mean engine damage.
It means the ECU is protecting you.
Why You Should Care
Because the ECU is already tuning your truck every time you drive.
You don’t need a dyno.
You don’t need to be a tuner.
You just need to look at the data.
Logging tells you:
  • If your fuel is helping or hurting (87 vs 91/93)
  • If your octane is actually what the pump advertises
  • When heat or elevation is costing power
  • If the tune is giving the ECU what it needs
What To Do This Week
If you’ve got an Accessport, run a quick 3rd-gear pull and look at:
  • Knock Correction Angle
  • Intake Air Temp
Not ready to log? No pressure.
Start paying attention. Ask questions. Stay curious.
We all start somewhere.
Closing Thought
You don’t need to be a tuner to understand your truck.
You just need the right things to look at.
I’ll be here regularly breaking down:
Knock control & octane
  • Torque & load limits
  • Gear-based torque mapping
  • Fueling strategy
  • Boost control behavior
  • And how all of this affects your seat-of-the-pants power and driving experience
If You're Curious
I’m CAMTuning — I remote tune the 2.4T Tacoma & 4Runner platform with Cobb.
If something in your logs doesn’t make sense, DM or post it.
We’ll figure it out together.
Question:
What fuel are you currently running, and have you ever checked your knock numbers?
CAMTuning
CAMTuning
Cam
NM
To go one step further from above, here's an example of a data log with limited parameters shown:
  • Intake air temperature (at the intake and at the manifold)
  • Engine speed
  • Knock correction angle
you can see the knock correction angle (yellow line) moves around -3, dips, then climbs to close to -2, but it also dips down to -3.8 on shift. The way to read this is to follow the RPM scale (white line) to where it peaks and then drops off, and that indicates a shift point.
The KCA in this log is what would be considered normal and would not be cause for concern.
2025 4runner 6th gen Tuning Facts - Understand Your 4Runner Like We Do at CAMTuning 1766781419605-ay
Tennessee USA
F350
Disclaimer: I am not a fan of “tuning” or mods. If I want more speed, torque, power etc, I’d buy a different vehicle.
Question for you: How does this impact the vehicles warranty? The ECU shows flash history. More so, what reliability testing have you done that confirms no adverse, out if spec wear downstream components.
CAMTuning
CAMTuning
Cam
NM
This is exactly the kind of discussion that I hoped this post would generate.
  • CAMTuning isn’t about chasing peak power or trying to turn a Tacoma or 4Runner into something it’s not. Power gains happen, but the goal is always driver experience — smoother torque delivery, cleaner throttle, and a truck that feels more predictable and comfortable to live with.
  • On warranty: nothing can void your warranty- That’s not how federal warranty law works, but anything (tune, intake, tires, lift kit, aftermarket electronics, whatever) can be used to deny a specific claim if they think it caused the issue. The ECU will show that the calibration has been changed, so it’s never “invisible.” I want people to be aware of that upfront.
  • Reliability-wise, I’m not pretending to have OEM-level durability labs. What I do have is a rapidly growing data set from customer trucks across the country, hundreds of hours of log review, and calibrations built to stay within the mechanical intent of the platform instead of pushing the edge, — safe fuel (safer than OEM actually), no knock, controlled torque, temperature-aware limits. I am certain that a properly custom tuned vehicle is safer than the OEM calibration in almost all cases.
Also worth noting:
  • This drivetrain is engineered to tow, haul, and manage far higher load under power than most people use day-to-day. We’re not pushing torque beyond what Toyota designed the truck to survive, so concerns about downstream components seeing “unrealistic” stress aren’t really aligned with how the platform is built.
If someone wants max numbers, I’m probably not their guy.
If they want their Tacoma or 4Runner to drive like it should have from the factory, that’s where I fit.
CAMTuning
CAMTuning
Cam
NM
Is this California legal?
Tacoma and 4Runner are 50 state legal for the i-Force application, and an EO is pending for the i-Force max. It won't be long for the hybrid to be able to ship to CA. I've already tuned a bunch of non-hybrid trucks in CA. They must be everywhere out there.
Thanks for taking the time and breaking all this down. With all the recent mods and these heavy ass "E" tires I may be in the customer base for a tune in the near future.
(y)
Tennessee USA
F350
Also worth noting:
Good response, Thank You.
CAMTuning
CAMTuning
Cam
NM
(y)
I'll be happy to help when you're ready! I've got a few PA customers running my tunes on gas and hybrid Tacomas.
T_Pomp
Anthony
Illinois
2025 TRD Off Road Premium
Session 1:
The Short Version
The ECU is:
  • Adding timing
The ECU is:
  • Removing timing
Possible causes:
Why You Should Care
Logging tells you:
  • Intake Air Temp
Closing Thought
  • Fueling strategy
If You're Curious
What is the typical cost of a tune?
ttominator
Waco Texas
You said;
  • Intake Air Temp
What and how would I go about this?
CAMTuning
CAMTuning
Cam
NM
Custom Remote Tuning — $400
This is the full CAMTuning experience. You’ll send in data logs, I’ll review them, and I’ll dial the calibration in until we’re both genuinely satisfied with how the vehicle drives. In most cases, customers are thrilled before I am — I’m picky on purpose.
Flash Map (OTS) — $200
A proven CAMTuning calibration that’s been validated on the dyno and the street. Unlike most “flash maps,” this still includes one data log review from me to confirm everything is operating safely and as expected.
What You’ll Need
Both options require the Cobb Accessport ($770). It installs in minutes and gives you everything you need:
  • Install or swap maps at home
  • Data log for tune revisions
  • Clear codes and diagnostics
  • Return to stock any time
No special skills, no shop visit
(Link to Accessport + tuning options here.)
You said;
  • Intake Air Temp
If you already have an Accessport, you’re basically ready to go. You can set up to six gauges right on the screen so you can see what the ECU is doing in real time. Behind the scenes, the Accessport is logging everything that matters and saving it internally. For remote tuning, I’ll send you a custom log configuration so it collects exactly what I need on my end. When you’re done logging, just plug in with USB and drop the files onto your computer.
If you don’t have an Accessport yet, that’s your first step. The link in my signature goes straight to the Toyota section of my site. For 4Runner specifically, you can grab what you need here:
(AP + Tune) or (AP Only) — whatever fits your plan.
Turbo_Tacoma
Zach
New Mexico + Southwestwern Colorado
2024 Tacoma TRD OR 6MT
Hey guys, just wanted to stop in here (Tacoma owner) and share that I met Cam two months ago looking for a comprehensive tuning experience for my 2024 TRD OR 6MT non-hybrid. For me that meant being able to monitor and log my engine as I load on the miles with as much power as can safely extract.
He got me all setup finally and it's a dream to drive how I envisioned it should be as an Evo/STi, ex-GRC owner.
In addition to literally looking forward to grabbing the keys, I can keep an eye on my engine both live with the AP and through actual data logging now.
My coworker picked up a 2025 4Runner TRD OR and at first he told me you can stop trying to convince me to join you in getting a tune, "I don't need more power for what I do", but after he drove with (and next to) me a couple weeks ago, he gets it!!! The whole nature of the truck changed and I rarely actually need to go WOT but the thing feels so healthy and happy. We both drive a lot for med sales and it's so nice to thoroughly enjoy the miles now.
Happy to share more of my experience if you guys are curious.
Until then, thanks again Cam!!
PS- This is a great idea to share/discuss this content. Fascinating what all goes into a fully formed production ECU these days!
CAMTuning
CAMTuning
Cam
NM
Session 2:
What “15.0 Knock Control Learned Value” Actually Means (And Why It Matters More Than You Think)
Most people watch their knock numbers, air fuel, and timing…
but they miss the value that quietly controls how aggressive the ECU is allowed to be.
In this platform, that's the KCLV — Knock Control Learned Value.
The Short Version
15.0 KCLV = the baseline(resets to this on learning reset).
It’s not “good” or “bad.”
It’s simply where the ECU starts.
From there, the ECU learns.
  • Higher than 15 (like 17–20) →
    “We’ve got safe combustion. I’m confident. Let’s run more spark.”
  • Lower than 15 (like 13–14) →
    “I’m hearing borderline knock or noise. I’m going to be cautious.”
KCLV doesn’t change timing directly.
It sets the ceiling — the confidence limit — for how much timing authority the ECU is willing to use.
Think of KCLV Like a Trust Score
15 = Neutral
18–20 = Trust earned
13–14 = Trust lost
It’s the ECU deciding:
“Can I trust the fuel and conditions enough
to apply the timing this tune is asking for?”
When KCLV Climbs Above 15
You’ll typically see this with:
  • Good 91/93 octane
  • Cool air temps
  • Clean combustion / no knock noise
  • A tune that the ECU “likes”
This is ideal.
It means the ECU has timing headroom and will use it when conditions allow.
This is where a custom tune + good fuel actually feel different on the road.
When KCLV Drops Below 15
The ECU has seen something it doesn’t like:
  • borderline knock events
  • inconsistent fuel quality
  • heat-soaked conditions
  • mechanical noise that sounds like knock (false knock)
It reduces its trust in the ignition strategy.
The result?
  • Less timing authority
  • Less power potential
Not always dramatic — but absolutely worth paying attention to.
Why You Should Care
KCLV is how the truck tells you:
“Can I do what this tune is asking me to do?”
This is where tuning and driving conditions intersect.
Even the best tune can’t force the ECU to be confident when the fuel isn’t supporting it.
If you want consistent performance:
  • Have your tune developed for the fuel that you intend to run
  • Watch KCLV trends
  • Watch fuel quality
If you’ve got an Accessport, log:
  • KCLV
  • KCA (Knock Correction Angle)
  • Intake Air Temp
  • Note what fuel you're running.
Look for the trend:
  • KCLV rising after a fill-up? → Good fuel.
  • KCLV dropping during heat soak? → Normal.
  • KCLV stuck at 15? → Needs more data; no confidence change yet.
  • KCLV falling over multiple pulls? → Start asking questions.
Just start paying attention. Ask questions. Stay curious.
Closing Thought
KCLV is the missing context for manyTacoma owners.
It makes the difference between:
“My truck feels inconsistent”
and
“I understand why my truck behaves differently day to day.”
Once you understand KCLV and KCA(covered in session 1),
you understand what the ECU is thinking
I’m CAMTuning — I remote tune the 2.4T Tacoma & 4Runner with the Cobb Accessport and Protuner Software.
If you see KCLV moving and don’t know why,
post a log or DM me.
Question:
What octane are you running, and does your KCLV ever move off 15?
(If you haven’t checked yet, that’s totally fine — you’re in the right place.)
