Rock Doc
Joshua
Alexandria
2025 TRD Pro and 2002 Tundra
Just talked to the dealership and they gave me the updated part numbers for left and right. PT989-35240-AG is rear left side and PT974-89251-AA is rear right side.
horbit
DFW
One of those parts says Taco in the description, we know the mounting points are different so it wouldn't fit.
If someone had access to the Toyota installation sheets for these parts numbers it would answer a lot of questions we have.
gvan1998
MD
I believe the 4runner has one rear tow hook mounting point on the passenger side. The part # i posted replacesthe black factory rear recovery hook.
The 2nd part # that someone else provided looks like its for the Tacoma, which has both left and the right rear tow hooks.
I might be wrong but that's my observation
kburrito
2025 TRD Off Road Hybrid
gvan1998
MD
Thsi!!!! we need TIS installation pdf
Rock Doc
Joshua
Alexandria
They just canceled my order the right side ending in AA is out of stock and none showing in the US they said I could re-order the left side ending in AG is in stock fyi. I was told by toyota parts dept the 03 was the old part number.
xp0nex
2025 4Runner ORP
Anyone want to update with the correct part # for both left and right?
Rock Doc
Joshua
Alexandria
4RUN/H TOWHK TRD RED 3P0
Product Specs
Brand
Toyota Genuine
Part Number
PT974-89251-AA
Color
TRD RED (3P0)
Rear Recovery Hook
Rear Recovery Hook, Right Hand
Part Number: PT974-89251-AA
1$104.99
horbit
DFW
As far as we know, there is only the right side PT974-89251-03 for the 4Runner. I don't know why @Rock Doc keeps plugging these other ones. I am interested to find out what they are.
xp0nex
2025 4Runner ORP
Got it. I placed an order for the right one but thought there was a left one also from reading the thread. Guess there is only one then.
gvan1998
MD
Functionally, why would someone use the bigger loop in the back?
I would think the small front loop is big enough for a soft shackle or d-ring shackle.
for me its more of the looks than function.
horbit
DFW
You can check your 4Runner, on the left side of the frame near the exhaust. There are no holes for a left side recovery point like the right side is mounted. The holes that are in the area are not even threaded to take a bolt. Seems like an open and shut case for there being no left sided recovery point.
Maybe other trims or future years will be different.
Rock Doc
Joshua
Alexandria
Not plugging the AA is what the Toyota dealership told me.
