jjbailey930
Potomac Falls, Va
HI - Looks great. I would like to do that on my Sport. Watched a vid on install on 5th gen. Assume it's the same. Can you link to instructions on wiring the aux switch? Or d these connect to parking light block?
mball269
2025 TRD Sport Premium
Can you provide a closer photo of the mounting of the lights?
LFGRTX
Kyle
2025 4Runner TRD Off-Road Premium Hybrid
I used a provided fuse tap and inserted it in the ignition circuit on the driver's side fuse panel.
Hello. How did you know determine those fuses are on the ignition circuit?
LFGRTX
Kyle
the underside of the fuse panel lid identifies the fuses
Oh shit, I’m an idiot. I didn’t know IGCT signified ignition circuit - makes sense. Thanks for pointing that out!
kburrito
2025 TRD Off Road Hybrid
Hi can you link which lights this are?
kburrito
Thank you for the link! From the picture you have of the fuse box, i take it that you had to make a hole for the cables to pass through?
