Lotzof4Runners
Bill
Seattle, WA
Nice ride! Wondering about those Nitto Terra Gapplers.
How do you like them? Have you run them in the rain?
I've got the KO3s on mine and the ride is terrible. Only other option in an 18" that is SL would be those Nittos. Had TG2's on my 2021 TRD Pro.. They were horrible, but I've heard good tings about the G3s. Any thoughts you could share? Thanks & Congrats!
Ericd6972
Ericd6972
Eric
Delaware
2025 TRD ORP
Once I put them on, my wife couldn't even tell the difference. They seem fine in the rain and they are very quiet.
AZGOLD
AH
Prescott
2025 ORP 4runner
I have found that the ride is terrible regardless of the tire. My ORP is still stock and it is the worst ride ever. The toyota branded bilstiens are dog crap for a shock. Unfortunately it will be a while until the big brands start coming out with suspension lifts. Stay away from the Wescott Designs preload collar lift too, unless you want the ride to get worse.
If you need to have a lift up front , just get a simple 2" spacer lift for the meantime until legit lift kits are available. Looking at the front struts , toyota made it so that you dont even have to remove the lower ball joint anymore to get the struts out. so, a spacer would be super easy to install
4R4Life
Sam
New Jersey
Toyota 4Runner TRD sports premium 2025
100% agree! I put KO2 on mine and it’s just horrible.. vibrates after 60m/h. Retuned back the KO2 and mount backed the stock tires.
Daronc
Daron
Santa Clarita, CA
2024 & 2025 Tacoma's & 2025 4Runner TRD Off-Road Premium
Looks great!!
I'm looking for the same set-up and look. Can you confirm that you used the Rough Country Level Kit strut spacer and the strut shim to achieve 2" lift or just the spacer.
Ericd6972
Ericd6972
Eric
Delaware
2025 TRD ORP
Looks great!!
I used both the strut spacer and shim
KRunner
PA
2025 4Runner Off Road Premium
Thanks for sharing! Your 4Runner looks great. This seems like the perfect setup for an even balance between looks, factory offset, ride quality, & improving the off road capability with a slightly more off road oriented tire without going full off road AT!
I’m considering going back to the factory 18 wheel & upgrading to this same exact Nitto tire & size.
What’s your honest take on the tire now that you’ve had it for a few weeks? Similar road noise & comfort to the OEM Falken AT3WA?
Appreciate your input!!
Ericd6972
Ericd6972
Eric
Delaware
2025 TRD ORP
So far it has been great. I don't drive as much as my wife but here and I both agree they are very quiet and drive like stock.
Meech
Michelle
2016 Toyota 4Runner Limited
2" Rough Country Level kit + Nitto Terra Grappler 33s 275/70/18 tires installed on TRD Off-Road.
Finally got around to throwing the Leveling kit on the 4runner. Super easy took me about an hour and now she's in the shop for alignment today. This is exactly the look I was going for, now just waiting on the trail hunter grille and the wife will be happy.?
looks great! Have been trying to decide between just a level or lift/ level and I think this decided it for me. how much tire poke Is there? Do you have a side pic to share to show how much the tires poke out?
Ericd6972
Ericd6972
Eric
Delaware
2025 TRD ORP
2025 Toyota 4runner 2" Rough Country Level kit + Nitto Terra Grappler 33s 275/70r18 tires installed on TRD Off-Road IMG_7577
2025 Toyota 4runner 2" Rough Country Level kit + Nitto Terra Grappler 33s 275/70r18 tires installed on TRD Off-Road IMG_7578
Meech
Michelle
Thank you, appreciate it! Im waiting on my Sport Premium, I think the look of the level and tire size should be pretty similar on my trim, don’t you think?
