JuliusBrown
Julian
Denver Colorado
Jeep 2020 Trailhawk
Radflo 2.5 Front Coilovers w/ remote reservoir.
Rear Radflo 2.5 shocks w/ remote reservoir.
Icon Tubular Upper Control Arms
Kings Sway Bar Link Kit
Timbren Active Rear Bumpstops
CBI Covert Front Bumper
Warn 10k Winch
Baja Designs S2 pod lights (yellow)
RRW 18" Wheels RG4-H +25 offset (27 lb)
Falken Wildpeak A/T4W Tires 35x11.5R18 (C Load 62.6 lb)
2025 2026 4runner 6th gen TRD Offroad Build - 2.5" Lift, Radflo Shocks, CBI Covert Front Bumper, Winch, Falken Wildpeak 35x11.5R18 front-park
2025 2026 4runner 6th gen TRD Offroad Build - 2.5" Lift, Radflo Shocks, CBI Covert Front Bumper, Winch, Falken Wildpeak 35x11.5R18 3-4 frnt-garag
2025 2026 4runner 6th gen TRD Offroad Build - 2.5" Lift, Radflo Shocks, CBI Covert Front Bumper, Winch, Falken Wildpeak 35x11.5R18 3-4 neigh
2025 2026 4runner 6th gen TRD Offroad Build - 2.5" Lift, Radflo Shocks, CBI Covert Front Bumper, Winch, Falken Wildpeak 35x11.5R18 rear wheel
2025 2026 4runner 6th gen TRD Offroad Build - 2.5" Lift, Radflo Shocks, CBI Covert Front Bumper, Winch, Falken Wildpeak 35x11.5R18 tire-pok
2025 2026 4runner 6th gen TRD Offroad Build - 2.5" Lift, Radflo Shocks, CBI Covert Front Bumper, Winch, Falken Wildpeak 35x11.5R18 neighb-front-3-4
2025 2026 4runner 6th gen TRD Offroad Build - 2.5" Lift, Radflo Shocks, CBI Covert Front Bumper, Winch, Falken Wildpeak 35x11.5R18 side offic
2025 2026 4runner 6th gen TRD Offroad Build - 2.5" Lift, Radflo Shocks, CBI Covert Front Bumper, Winch, Falken Wildpeak 35x11.5R18 flex
2025 2026 4runner 6th gen TRD Offroad Build - 2.5" Lift, Radflo Shocks, CBI Covert Front Bumper, Winch, Falken Wildpeak 35x11.5R18 mtn
2025 2026 4runner 6th gen TRD Offroad Build - 2.5" Lift, Radflo Shocks, CBI Covert Front Bumper, Winch, Falken Wildpeak 35x11.5R18 side-ledg
hammerhead
NC
2007 4runner sport, 2025 4runner
Well, how’s the ride compared to stock?
JuliusBrown
Julian
Denver Colorado
Jeep 2020 Trailhawk
The ride seems pretty good so far. I noticed the stock TRD Offroad suspension was smooth on the bumps but a little loose on corners at speed. The Radflo's seem a little stiffer in corners at speed but maybe a little less plush on the bumps (at present). Will have to see how they settle in over time.
Scarlett
Wellsboro, PA
Rear Radflo 2.5 w/ remote reservoir.
Warn 10k Winch
Those 35s look right at home. Did you have to do any trimming in the front?
Rellims
Sean
ORP - Underground
Warn 10k Winch
If you didn't do the work yourself, what shop did you use?
JuliusBrown
Julian
Denver Colorado
Jeep 2020 Trailhawk
Minor trimming on forward-facing plastic flap behind the wheel well liner where it protrudes into the tire path. This is the most common rub point at full lock. Use a heat gun to soften and a Dremel/reciprocating saw for clean cuts. Also removed factory mud flaps on front wheel wells (kept rear mud flaps).
2025 2026 4runner 6th gen TRD Offroad Build - 2.5" Lift, Radflo Shocks, CBI Covert Front Bumper, Winch, Falken Wildpeak 35x11.5R18 IMG_4647
DocASim
Al
Las Vegas
2014 Mercedes-Benz C63 AMG Edition 507
Very nice build! I'm looking at something similar. Same CBI bumper. Trying to decide what suspension to swap. OME MT64 2135K, ICON 2.5 Stage 8 (as I like the adjustable compression) and I've looked into the RadFlo 2.5. I'll be curious how you like the Radflo's?
JuliusBrown
Julian
Denver Colorado
Jeep 2020 Trailhawk
I like the Radflo's but I'm not sure I love them. I'm glad I did not go with a spacer lift (as I get the long travel) but the Radflo's are not as plush as I hoped for. Maybe they will open up in time. The stiffness is likely due to the preload and higher spring rate they used to get the lift and handle the weight of winch, bumper, & sliders.
JuliusBrown
Julian
Denver Colorado
Jeep 2020 Trailhawk
I took my 4Runner up to Yankee Hill this weekend (you can see a YouTube of the trail from a Jeep owner here: ). The trail was washed out a lot from years ago when the youtube was made, so it is a harder trail now. My 4Runner with the lift and 35's had no issues. I see now why they added all the preload and the spring rate as I never scraped the underside on rocks once (unlike my buddy with a Rubicon on 33's who had multiple scrapes). I just wish maybe they had gone with a little less preload and spring rate so the ride was a little softer. But I guess that would mean less lift height and maybe some more scraping the underbody on trails like Yankee Hill!!
2025 2026 4runner 6th gen TRD Offroad Build - 2.5" Lift, Radflo Shocks, CBI Covert Front Bumper, Winch, Falken Wildpeak 35x11.5R18 IMG_4665
2025 2026 4runner 6th gen TRD Offroad Build - 2.5" Lift, Radflo Shocks, CBI Covert Front Bumper, Winch, Falken Wildpeak 35x11.5R18 IMG_4674
2025 2026 4runner 6th gen TRD Offroad Build - 2.5" Lift, Radflo Shocks, CBI Covert Front Bumper, Winch, Falken Wildpeak 35x11.5R18 IMG_4667
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
Which spring rate on the coilovers?
