Exterior MOLLE Panels compatible with stock Trailhunter Roof Rack
con5tant
4runner ORP Max
Don't remember off the top of my head but check the accessory bags you got when you bought it. It's in there in a plastic bag.
I did not receive any accessory bags. I tried a T35 which fit but also seemed like it would be slightly too small (I don't want to strip it). Next size at T40 is too big. I am not aware of any Torx sizes in between so I'm going to assume that it's a T35, unless it is not a Torx.
jimmy
Bozeman, MT
2025 Trailhunter
sliver
Guy
Atlanta GA
Let me know if that works. I'll pull the trigger on those if it does.
sliver
Guy
Atlanta GA
It's an ARB roof Rack, I bought some ARB anchors for it, they work. I just need to find a way to have some side molle panel attached to that rack. I'm waiting on the edge of my seat for someone to tell me, I made it happen with such and such hardware.
kgolive
Kevin
Huntington Beach
25 4Runner TRD ORP
I called Rago and they said it does not work for OEM arb rack. Currently no one has a molle panel that works with the OEM arb rack.
sliver
Guy
Atlanta GA
Let me know. I'm starting to debate if I will budget a new roof rack that would support it :( I hope not, the whole thing about the Trailhunter is it comes with everything...
K2mia
4Runner Trailhunter
But it doesn't - the 3/4 roof rack rating of 165lb is limiting, why couldn't they spring for a full roof rack (Prinsu which is actually about the same price) which has double the dynamic rating. Was a let down for me, but beside that I love everything else about my TH.
grey
california
2025 4 Runner Trailhunter
Hi Everyone, update to all that I tried the following molle with my ARB mounts and it’s a no go. I bet it will work with a bit more customization but I didn’t want to try anymore. I just wanted to post on here so for the rest of the Runners with stock roof rails here is a good option for all based on price $249 pair and the craftsmanship. I found these on Amazon. JOYTUTUS Rear Window Molle Panel... https://www.amazon.com/dp/B0FHHBVYZS?ref=ppx_pop_mob_ap_share
hussch85
Hussein
Cypress, CA
2025 4runner Limited Hybrid
Has anyone tried the caliraised molle panels that use strong suction cups instead of rack mounting? or has anyone found something that'll work with ARB roof rack?
