MESO Customs map lights / dome light installed
toyoda80
Beau
The meso customs map light upgrades are sold out everywhere/ on back order. I got some from https://www.bustabeatgeorge.com/products/4g-tacoma-3g-tundra-3g-sequoia-dome-light-dual-color
I was skeptical about buying from this site but they use the shop app which I have used many times so that gave me a little confidence. I messaged him the same day and received a quick response to my questions. It was shipped within 2 days and I received it right away. If you’re looking for this product and don’t wanna wait, you can try at the link above.
install was super easy as other members have mentioned. The 2024 Tacoma install video was pretty spot on. I didn’t need a torx bit as it was just a small Phillips head needed for the 2 inner screws. I will say that you must commit to the removing of the housing for the first step. It really does require quite a bit of force to remove. I pulled straight down on the windshield side of the housing first. It really feels like it’s not gonna pop off but just trust that it will.
2025 4runner 6th gen MESO Customs map lights / dome light installed IMG_0523
Here they are installed. I forgot to take pics during the install so all I can provide now are after the fact.
2025 4runner 6th gen MESO Customs map lights / dome light installed IMG_0530
2025 4runner 6th gen MESO Customs map lights / dome light installed IMG_0529
There are 2 of these blue clips holding the housing to the metal. That's it. They simply plug up into the holes. No tabs to press or anything. As I mentioned before, it's held up there quite securely but maybe if you see what's holding it up there, it will ease your mind about how much force is needed to just pull down on it.
2025 4runner 6th gen MESO Customs map lights / dome light installed IMG_0525
For removing the trim, if the tab looks like this and is SMALL, it will just pull out.
2025 4runner 6th gen MESO Customs map lights / dome light installed IMG_0526
If the tab looks like this or a larger version of the previous picture, you will need to move the tab to release it.
2025 4runner 6th gen MESO Customs map lights / dome light installed IMG_0527
One of 4 holes that need to be drilled in the housing.
I spent the most time trying to remove the outer bezel without beaking any tabs (it can be done).
@Van Solo has a post in the lighting section with the link to the video of installation in a 2024 Tacoma as well as more photos. See his DIY video here:
https://www.4runner6g.com/forum/thr...-dome-map-light-upgrade-white-red-modes.5897/
mtk_rob
Rob
New York
2025 4runner Trailhunter
I cannot for the life of me get the housing out and I'm puling HARD. It's just pulling the bezel trim off. What's the secret?
deeda
Dee
San Diego
2025 4runner
This fit the 25 4runner??
mtk_rob
Rob
New York
Finally got it. You have to pull HARD! Had to wear gloves because it was slicing up my fingertips too.
I ended up breaking the outside trim. That was even more diabolical than removing the console (and I am somewhat experienced in trim removal/replacement). I had to fix broken tabs with crazy-glue and then add matte black spray paint. It looks like the only way to get the outside trim piece currently would be to purchase 63650-AK010-C1 which lists for $336!
The connectors needed some jiggling before the back window worked and it stopped complaining that the SOS was bad and to contact the dealer.
toyoda80
toyoda80
Beau
Really sorry I didn’t see your original reply. If the outer trim is the only part moving, you had to reach in further with your finger tips and pull on the housing. Glad you got it figured out.
