zeedog
NJ
Wasn't as bad as it looked watching the swap on youtube. Got the white ‘TOYOTA’ overlay letters to match, installed Rough Country 20” LED light bar with the Rave bracket.
Upper grill OEM part number 53101-35160
Lower grill OEM part number 53113-35030
2025 2026 4runner 6th gen TRD Pro/Trailhunter Heritage Grille Swap (Upper & Lower Grill) on SR5, with part numbers TRD Pro:Trailhunter Heritage Grille Swap (Upper and Lower Grill) Complet
2025 2026 4runner 6th gen TRD Pro/Trailhunter Heritage Grille Swap (Upper & Lower Grill) on SR5, with part numbers 2025 4runner TRD Pro:Trailhunter Heritage Grille Swap (Upper and Lower Grill) Complet
2025 2026 4runner 6th gen TRD Pro/Trailhunter Heritage Grille Swap (Upper & Lower Grill) on SR5, with part numbers 546626794_10239154156410136_3481438963715789106_n
df525
2025 4 runner sr5
wow, did you install it yourself? I'm thinking about doing the same thing. How is that RC light bar, is that the
RC: 20 Inch Black Series LED Light Bar- Single Row
Rave: Universal 18-21" Light Bar Mount for 2025+ 4Runner Grille
zeedog
NJ
Yeah I did it myself, took about 2 hours taking my time. And yes those are the light bar and brackets I used.
Josalbrec6G
joe
cincy
2025 4Runner 6G
How was the camera relocation. I read you need a new cable, is that true?
zeedog
NJ
Oem part number PT948-89250-15
Twisted
5th Gen TRD -> 6th Gen TRDORP
You do not need a new cable. You can cut the existing one out of the existing harness to reroute it but buying another cable eliminates that step. You just leave the OEM cable in place and install the new one to the new location.
chrismacc
chris
dallas, Ga
2025 4runner
Looks great!! I was thinking of just doing the upper grill, but the lower looks great also.
Twisted
Thanks.
For me I wanted the lightbar. I needed more forward light and the OEM setup is the cleanest way I've seen it done. I also don't like how the non pro lower wasn't the same pattern as the TRD trims. This way it all matches. And lastly, I couldn't see doing the work to swap the top and not just doing the couple more steps to do the lower.
Maximus4R
Adam
Nashville
TRD Pro:Trailhunter Heritage Grille Swap (Upper and Lower Grill) Complete.webp
2025 4runner TRD Pro:Trailhunter Heritage Grille Swap (Upper and Lower Grill) Complete.webp
Any pics or thoughts on the rough country light bar for this use case? I keep eyeing that one but stick between that and a pro diode dynamics ss20
topo_htx
pete
texas
2025 ORP hybrid
Looks great!!! I did the swap a week ago and one of m favorite changes. I'm actually not mad at the fact that it takes a lot more work than it did on the 5th gen. Won't see it as commonly done.
Man, this looks SO good! I had hoped to find a way to do this when I'd decided on an ORP instead of a Trailhunter, but not sure I want to go through the effort. Seeing yours and others in this thread makes it so tempting though!
Maximus4R
Adam
Nashville
Agreed. This looks amazing. I’m even digging the double dual look in each oem fog position. Wish diode made a kit like this. Wonder if it would look stupid if I ran one white and one amber c2 on each side. 🤔
