Finally got my Westscott Design preload collar lift installed with Wildpeak AT4. I’m in love😍😎
4LifeRunner
4LifeRunner
Ben
Quebec, Canada
Toyota tacoma
@4LifeRunner can you do me a huge favor and measure the total height of your truck as it stands?
My garage door opening is around 210cm. I believe the stock Trailhunter is already just over 2m, so I'm wondering if this lift + 35" tires (exactly what I want to do) will put it over the 210cm mark. Thank you!
Hi @generic.user it's hard to mesure it with a tape :O But I'll say around 200cm (+/-78'') at the top of the cross bar. My AT4 are 33''.
B Rad
Brad
Edmonton
4 Runner
I have the same size of tire. I installed my pre loaded collar kit with the 3/4” in rear and 2.5” in the front. However I totally forgot to pre measure my vehicle height. What did you achieve for a height after installing the kit?
Gerardo
Gerardo
PNW
@g0.0utside @ctngo82 @papadop88
Lift: Westscott Design preload collar 2’’ front 3/4’’ back
Tire: 285/70/17 Wildpeak AT/4
Wheels : unknown
The ride stay almost the same has the original. I’m really impressed ? and I don’t check my mpg ??‍♂. If I was I dind’t bought this ride ?
@4LifeRunner Looks great!
Can you confirm, you mentioned 2" front. The Westcott Designs Preload Collar Lift is 2.5" front (including the .5" top spacer). Did you leave out the top spacer?
Thanks!
First I was afraid too loose quality ride, but in and out the ride it’s pretty pretty the same and with the AT4 in load C the smoothness of the ride remains. Before I had an ReadyLift leveling kit on my Taco and this was not the thing. I thought the preloaded collar makes all the difference.
You don’t lose ride quality if you’re in a TRD Pro model I can vouch for that. I also would think any the other trims would rise super close to stock. No issues. I feel like my pro rides better now.
Dave
Newhampshire
26 4Runner trd off road premeum hybrid
Yes im.also wondering if you left the top plate off? The kit will.give you 2.5 if the lower collar and top plate are both used . Im looking for a picture of someone's truck without top plate. Cant find anyone that did it
