AdFour
Washington
Depends on what you prefer, there is no best.
This is one solution you can implement today, and thats what matters.
There may be better ones but that would be long term, in the meantime do this.
coloradomarmot
2025 Pro
that sucks, I thought they’d fixed that by now. I’ll definitely be doing this when on road trips (lucky enough to have garage at home).
DocASim
Al
Las Vegas
2014 Mercedes-Benz C63 AMG Edition 507
So sorry about this. I would recommend a Faraday box to store your keys when you aren't using them. It blocks the signals in and out of the box. It prevents those scumbags from relaying your signal to their device.
We use a faraday box for all our key fobs.
s3lekta
M
ON, Canada
Thank you.
Yes we bought a tracking device that it was bought through the dealership, we called them right after we found out that the car was stolen, very rude customer service, no helpful.
sorry to hear, just saw your post recently that you got it.
what tracking system did you use? Do you have your keys in a Farady bag?
if you are using the digital key, you need to have the app on your phone and then you must have bluetooth turned on.
if you want to thwart cloning, you turn off bluetooth. simple as that.
but you must have the remote connect subscription and the digital key option (PIO that costs $275) when you buy your vehicle as its a hardware restriction. right now i dont know of a way you can add the digital key feature after the fact.
most car's that are stolen are using the fact that most fobs send out a constant signal so when you get close to your vehicle it knows to unlock when you grab the handle. hence the videos you see people carrying a antennae array to pick up a fob signal to clone.
one way to thwart this is to have a hidden start interlock regardless if they clone the key.
another option is to put your key fob in a faraday cage when at home
there are some canbus interlocks that require you to input a pin to start the vehicle (but this will defeat remote start for cold climate areas)
to solve the cloning issue while you sleep, you can turn off your fob from sending this signal as stating in a post above.
below is the process for using the digital key for toyota's
2025 2026 4runner 6th gen Stolen! Key fob cloning theft method used to steal 2025 4Runner 6th gen 1756153929712-qh
2025 2026 4runner 6th gen Stolen! Key fob cloning theft method used to steal 2025 4Runner 6th gen 1756153965948-nv
2025 2026 4runner 6th gen Stolen! Key fob cloning theft method used to steal 2025 4Runner 6th gen 1756153992759-6o
2025 2026 4runner 6th gen Stolen! Key fob cloning theft method used to steal 2025 4Runner 6th gen 1756154021792-py
juan mesa
Juan
Ontario, Canada
2018 Toyota highlander
Thanks everyone for your words.
The truck was found by the police 45 minutes away from home, unfortunately the electronics were pulled out, window broken, I’m busy dealing with insurance and police, also because the car is not working at all, one window is broken and the other 3 are down the car got all wet inside because it was raining in the morning, it’s so upsetting, insurance just tells us no to worry that is going to get fix, I just want my new truck like it was, I had only put 91 kilometres.
a faraday cage or bag would be more convient, the process of turning off the fob will get tiresome really quick
the turning off the fob is mostly for a long term solution for like when you go on vacation or something else for long term.
its not really meant to be done on a daily basis since you need to initiate the process when you leave your vehicle and when you return to the vehicle to turn the fob back on.
the instructions are in the manual
