Tire Recommendations for factory 18" wheels (TRD Off-Road Premium)
jofe
What are you guys’ thoughts on load ratings? I was really leaning towards the 285/70/18 but I see that anything over 265 (like 275 and 285) becomes an E load tire instead of an SL tire and I’ve read about people saying that this really affects ride comfort. Thoughts?
Ericd6972
Ericd6972
Delaware
2025 TRD ORP
It definitely affects ride comfort. An E load tire is also heavier which affects fuel mileage. I went with a standard load on my wife's because the only time she will be off road is driving on the beach. 275/70r18 Nitto Terra grappler. Had zero issues with rubbing and they drive great. Just added leveling spacers.
2025 4runner 6th gen Tire Recommendations for factory 18" wheels (TRD Off-Road Premium) IMG_7673
DangItsDen
Hayden
Speaking from experience, E load feels like wagon wheels on these trucks. I had a set of ko2 in 285/70/17 Load E on my 5th gen for 70k miles. Great tires. Great offroad. Super long tread life. Not a single flat in the 7ish years I ran them including in Moab on some rocky terrain. But they made the ride quality really harsh and took a good 2mpg off the average because of weight. On that truck I now have the same size ko3 but in a load C, and it is a MUCH more comfortable ride. Haven't tested them offroad yet but short of a sidewall puncture, I suspect they will perform similarly.
I wish more tires were available in these sizes in C or even D ratings. The ko3 doesn't come in C for any 18" wheels or I would be buying this immediately for this truck. SL rating will be more comfortable for sure, but not exactly tough if planning to do any actual off-roading.
Twomstone
Connor
Manitoba - Canada
NA
Definitely does. E's are better off on a 2500 series vehicle or someone towing heavy or aggressive offroad. I feel like a C load is a perfect mix of lighter but still durable enough for offroad. I'd be more hesitant offroading too much with an SL tire. But if you're just everyday driving and some gravel roads SL would be great.
Bobafett
Pennsylvania
2025 Trd ORP
I ordered 285/70r18 ko3s which are getting put on my stock off-road premium Wheels tomorrow. Does anybody know if I need to make any mods like the crash brace or liner?
Boba: Based on everything I've seen, I'll bet (and am hoping) that on the +55 offset wheels these 285's worked fine - but its been a few weeks: is my bet correct?
Did you look at the clearance at full droop and compression and all steering angles to be sure?
I'm headed down this path with +45 offset wheels and looking for every example of success.
And photos would be great too! (And any recommendations for offroading in PA? I'll be headed up to central PA from VA several weekends this fall and might try to find some time to do some wheeling.)
Bobafett
Pennsylvania
2025 Trd ORP
Mike, they fit with no problem. I removed the crash braces. Probably wouldn't need to even but it was pretty close, too close for my comfort. I added inch and a half wheel spacers next. For this, I had to tuck the front felt liner forward. I also had to trim a little tab where the air dam used to connect as it rubbed on that slightly at full lock in reverse. I was ok with that since I never intend on putting that thing back on lol.
I've had zero issues with those very minor modifications, even when compressed. (Although I'm not sure I hit full compression)
As for offroading, there's AOAA, Famous Reading Outdoors and Rausch Creek. Let me know if you hit any up, I'd love to join!
Great Info. Thanks!
Biff
2025 4Runner ORP
That's great you went with the 285's K03's. I'm getting my new 2025 ORP next week and asked the dealership to swap the tires on factory rims for the 275/70/R18 K03's. The 4runner will have no modifications so I hope there will be no rubbing, especially if I'm full lock going into reverse and such. Since your 285's seem to fit no problem I'm guessing I have nothing to worry about.
Cheers!!
sjbiss
Stephen
Buffalo, NY
I'm looking to either go 285/70r18 or 275/70r18 which would be a 33 or 34. Leaning more towards the 285/70, just want to make sure they don't rub before I buy them. The 265/70r18 on there now, which like you said is about the same diameter as the 285/65 in my opinion looks a little too small with stock suspension and would definitely look a little funny with a leveling kit. Picture below is a 285/70
Do you have +45 or +20 offset wheels?
