ah4rsr5
Abraham
VA
2025 4R SR5
The only way to get accurate MG estimates is going based off the actual consumption. The onboard computers are estimates (Usually inaccurate) at best. Ive used an App like Fuelly on all my vehicles that I track fill-up by fill-up based on actual consumption. We should have our Platinum here in a week or so. Once we get through a few fill-up I'll post here.
This is true... although what's showing on my onboard computer is lower than actual calculations by 0.5mpg.
So if it shows 22.5mpg on my screen, it's usually calculated at 23mpg
Burgi
mike
NC
sr5
5k update. Still sitting around 21.5mpg. I have noticed in the last month by mpgs have dropped by about 1mpg. Not sure if this is due to the fact that it’s been super hot here and I’m cranking the AC on most drives.
2025 2026 4runner 6th gen Real World MPG by Owners (gas non-hybrid 4Runner) - Post Yours ⛽️ IMG_3311
RogueWarrior65
Blair
I'm getting into the habit of resetting the average fuel economy whenever I fill up. My latest is 20.8 which is operating under the following conditions: city driving, Normal drive mode, A/C on, elevation above 5000 feet.
I'm now going to try a tank's worth of Eco drive mode.
25togo
Michael
Connecticut
2010 370Z Roadster / 2011 4runner / 2025 4runner
I did a 55-mile mpg test with my 6th generation SR5 (52 miles of highway / ~3 miles of stop & go). I got 27.5 mpg. The cruise control was set on 70mph, several hundred feet above sea level, no wind, ~80 degrees and the air dam attached. I verified this by the gas being topped off before and after.
CORMC
RMC
4RunnerSP2025
30/70 - City to Highway
87
21.4 MPG since my purchase in May.
3,000 miles.
Sam
Illinois
BMW X7, Tesla model 3
Over 4200 miles. I reset at every tank full. Always 87. 50-50 city highway on eco mode. Very conservative drive style, getting 24 MPG and higher on each tank. Accelerate slowly, anticipate braking and allow to slow down by coasting. Drive speed max 55-60 MPH. In all very boring drive style but exiting MPG.
ah4rsr5
Abraham
VA
2025 4R SR5
Yup I get the same!
Tested out driving in Sports mode and a little more zip and quick acceleration and I average 21-22... not much difference for more fun!
Same here.
outdoorCO
CO
2025 TRD PRO
I know this a non-hybrid thread but here you go.
TRD PRO
Put roof rack and awning on around 1500 miles
70/30 highway city
Lots of mountains
Bit of off-roading
Mostly 91 octane
20.8 mpg at 1950 miles and have never reset trip computer . I drive in different modes but nothing consistently.
SouthCoast
Houston
2025 4runner TRD ORP
MPG figure - 20.3
How many miles so far - 2907
What octane gas you run - 87
% mix of city / highway - 45/55 ish
Drive Mode used - Eco mostly
Driving style - conservative ish
Just got back from an Austin to Kingwood trip. Averaged 27 on the highway in eco at 75
bakutheleo
2025 4Runner i-Force Max
Question for folks with larger than stock tires: When you put on larger tires, is there a setting somewhere in the car's system to tell it that? If not then MPG calculations will all be wrong, whether you look at the dash display or calculate it based on how much fuel you put in at the pump. I can see some difference in actual mileage, but I would not think all that much.
