Add as Subwoofer - 2025 Trailhunter with JBL Audio
Louisiana
I recently installed a sub in my 2022 4Runner and decided to add another one to my Trailhunter. For the setup, I used the 10" Rockford Amp/Sub combo, which sounded great in my previous 4Runner. To make the install easier, I went with the Tacotunes kit, since I have the JBL speakers. I also ordered the speaker wiring harness and remote turn-on kit (skipped the LCI Pro, since the sub can handle high-level inputs).
One of the advantages of the Hybrid setup is that the battery is in the back, which made running the power wires super simple.
I also had to disable the artificial engine noise, as another post here mentioned. Without doing that, the sub produced a low rumbling effect. I picked up the Carista app and was able to disable that feature with ease.
I'm really happy with both the install and the sound quality.
https://tacotunes.com/shop/2025-toy...-package-modified-signal-post-jbl-amp-signal/
https://www.amazon.com/dp/B007AQ2W2Q?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
https://www.amazon.com/dp/B0BBS73F6J?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_2
tommyd52
Tom
Maine
This may be a stupid question, but did you install your new sub in addition to JBL sub that comes OEM? Also where did you located your sub? Would love to see pics!
jrenzag
Raleigh NC
Tommyd52,
Check out this thread for some pics of a different install. Yes, I connected directly into the existing JBL sub's wiring and both operate (but the factory JBL bass is turned down really low and the new aftermarket sub's gain is turned up).
https://www.4runner6g.com/forum/thr...led-w-removable-subwoofer-enclosure-box.3979/
tommyd52
Tom
Maine
Tommyd52,
Yeah I saw that thread a while back. I guess I don't see the point of taking up more room if there is already a JBL sub in a specified place. I thought you may have replaced the existing Sub with your new one in the same location.
jrenzag
Raleigh NC
Hmmm. I'll try to respond to your comment... (1) The factory sub sucks as you really have little to no control of it's output without crashing the entire set of speakers. The system gets muddy and strained when you turn up the bass. (2) You get way cleaner and much lower, crisp frequencies with the aftermarket sub. (3) I can easily remove it whenever I need space. I purposely installed it with a quick plug to its dedicated amp.
tommyd52
Tom
Maine
Thanks for the info. In my 5th gen, I’ve had an amp/sub combo under my front passenger seat. Disappointed to hear the JBL. OEM is junk but not surprised lol.
g0.0utside
2023 Bronco BadSquatch
Will the new sub still work if you completely remove the factory sub? If so, why not just install the new one in the same location as the factory sub?
Louisiana-Cajun
Louisiana
I left the factory sub alone, it’s really not that great. The Rockford sub won’t fit in the factory sub location-see pic. I was also able to hard wire an always on cigarette lighter plug to all the supply power to my mini fridge. Sub sits right behind the driver rear seat.
2025 2026 4runner 6th gen Add as Subwoofer - 2025 Trailhunter with JBL Audio IMG_1665
tommyd52
Tom
Maine
Well this is intriguing… wonder if putting this in on a premium trim will boost the JBL sub quality…
Speefk
Rob
Illinois
2025 4Runner TRD Off-Road Premium, 2021 RAV4 AWD hybrid
I installed this amp and it hasn't helped the OEM sub at all. It's boosted the whole system nicely. It's worth it, but the OEM sub barely contributes to the whole listening experience
6thGen1419
Peter
New Mexico
Pictures please. Really interested in where and how you mounted it and the amp.
Striker53
Sean Ruth
Prince George
2025 off road Premium
Has anyone just replaced the factory JBL sub with a different better sub? If so, did it help
6thGen1419
Peter
New Mexico
It won't help because their expectations are unrealistic given the way Toyota has designed the JBL premium sound system in the 4Runners with that option. Bottom line: subwoofer is tied to the front channel and there's no independent subwoofer level adjustment (other than the system-wide bass level adjustment). Personally, I think the current design is perfect. Current system implements perfect representation of the original recordings' mixes. I suspect (don't really know for sure) that these people want an artificially boosted, booming bass that propagates to the surrounding cars. For me, the system is perfect for accurate representation of the originals for things like Jazz and Bluegrass and Classical.
6thGen1419
Peter
New Mexico
Saw this YouTube video adding an amplifier to the 6th gens with the JBL system to make things louder.
