Will 34” tires fit on 4R TRD OR without a lift or spacers?
Van Solo
Van
Calgary / Canada
Rellims
Sean
ORP - Underground
Not according to our brother Rellims since his was stock wheels and 275 caused issue's
No, got confused, stock of course no rubbing. I upgraded wheels and tires at the same time and it rubbed.
Van Solo
Van
Calgary / Canada
Now we got all the Info....
Maximus4R
Adam
Nashville
Ahhh. Super helpful, thank you! I worded my question really badly but you answered anyway. I was hoping I could get away with the next size up with a 1.5” lift in the front. I have a set a the TRD Pro rims on the way so guessing I’ll run into running issues similar to yours if I don’t do anything over stock.
Van Solo
Van
Calgary / Canada
Maximus4R
Adam
Nashville
I had some 275/70r18 KO3’s put on my ORP with the TRD Pro OEM wheels. No rubbing at all from what I can tell on normal streets or at full lock. It’ll be a few weeks before I can get it on anything besides pavement.
2025 4runner 6th gen Will 34” tires fit on 4R TRD OR without a lift or spacers? IMG_1001
2025 4runner 6th gen Will 34” tires fit on 4R TRD OR without a lift or spacers? IMG_0998
2025 4runner 6th gen Will 34” tires fit on 4R TRD OR without a lift or spacers? IMG_0996
6GRunner
Brian
2024 BMW 230i, 2024 Tesla Model Y, 2020 Jeep Grand Cherokee
Looks great with the TRD Pro wheels! Does it currently have a leveling kit or other lift installed? If so, what did you go with? i apologize if this has already been asked and answered….
Maximus4R
Adam
Nashville
Hey! No leveling kit or anything as it sat here with zero rubbing. Unfortunately I had some serious balancing issues with the KO3s. Discount Tire tried to correct but they shook the entire wheel at highway speeds. I have the stock Falkens back on now. They don’t look nearly as aggressive but they aren’t horrible and ride perfectly. I’m going to give the 275/70r18 another shot soon, I just couldn’t keep going back to have them tweaked right now.
2025 4runner 6th gen Will 34” tires fit on 4R TRD OR without a lift or spacers? IMG_1017
2025 4runner 6th gen Will 34” tires fit on 4R TRD OR without a lift or spacers? IMG_1015
2025 4runner 6th gen Will 34” tires fit on 4R TRD OR without a lift or spacers? IMG_1019
k9Hiken
jesse
New Kent Va
2025 SR5
Since the K03 were E load, look at the Toyo AT3 E Load in the 275/70/18. I’m still waiting on my SR5 to show up from the QC hold at port. I picked up a set of the Off-road Two Tone OEM wheels and have a 1.25” Peak Suspension front leveling spacer. I will run either the 275/70/18 or the 265/70/18 Toyo’s depending on the front fender gap and room when I put the spacer on.
Will 34s fit on a TRD Pro without a lift or any modifications?
I was able to fit 285/75R17s on TRD OR no problem with Falken AT4W and 30mm offset. I'll post pictures when Black Rhino releases the wheels!
I'm jealous and a bit surprised that the 34.1" (per falken web site) 285/75r17 fit but my 33.7" Toyo 285/70R18 do not: definite rub both on crash plate and front felt. This is with +20 offset TRD PRO wheels on my ORP. Hard to believe that 10mm offset would make that much difference but apparently it does.
But to answer the original question: NO, 285/70R18 do not fit on ORP - at least not with +20 offset (wishing the +45 offset TRD black wheels were in stock and I would have gotten them.). Note: I also put in the Peak spacer (5/8" spacer for ~+1.25" level on front) - thought that would lower the risk but no. Crash plate coming off, I guess. Open to all advice but wanted to put my specific experience out there for this question.
k9Hiken
jesse
New Kent Va
2025 SR5
Powder coat the OEM Offroad wheels and then run the 285/70/18’s.
At this point I'm probably not going to do this, but it is a good suggestion. Thanks
Roach011
James
north texas
bronco 6g
2025 4runner 6th gen Will 34” tires fit on 4R TRD OR without a lift or spacers? IMG_0477
+25 offset wheels needed to fit, removed the back bolted on crash plates. no rub at all.
Toyo OC AT3 285/75/17 - 33.8 in overall
