Aftermarket Soft Touch Interior Materials to Replace Hard Plastics in the 2025 4Runners?
AR1978
Chicago
2015 4Runner Trail Premium
After watching several reviews on the 2025 4Runner I was surprised by the hard plastics on the new model. Specifically on the top of the door panels and side inserts one the doors on the Off Road Premiums and below trims. The actual arm rests have padding though.
Not a deal breaker but I can't help but notice my 2015 4Runner has soft touch materials in those spots on the doors. Any aftermarket solutions to this?
NPS Ranger
Ralph
San Diego
4Runner 2005
I am also looking for the same thing. I have a 2005 4Runner SR5 and I rest my arm next to the windows when driving. My 2005 have a soft touch material on the time of the door next to the window. I would like something like that for my 2025 4Runner also. Hope someone post a good answer.
Hacksaw
az
2025 4runner TRD-ORP
Also hoping a 3rd party addresses this. Even on the Off Road "Premium," the driver/passenger window sill is hard plastic, and the mid-door armrest "padding" is the minimum possible they could get away with and call it soft touch. If you press your finger on it, it's probably 1/8" of open cell foam so it barely passes as soft touch.
I haven't tried it but I'm guessing all these "arm-touch" panels pop off with a pry tool so an aftermarket replacement should be feasible.
In the worst case, if all these panels from the Limited trim level are available as Toyota parts, that might, in theory, work. But they will be hugely overpriced.
JR1
Joe
Missouri
I like the hard plastic as they are SUPER EASY to clean. After a day out with the windows down and sunroof open, it's so easy to wipe these down. Then again I am pretty anal when it comes to keeping my 4Runner clean. My 2
HVLA
Lexus
My gx460 has soft touch and is easy to clean.
Hacksaw
az
I don't understand your point. A covering doesn't have to be porous to be soft and/or have padding underneath. Easily cleaned non-porous, soft-touch and padded materials exist in practically every line of cars.
JR1
Joe
Missouri
I think the harder plastic is more durable and easier to clean. It's just my preference.
AR1978
Chicago
Would it be removing the hard touch plastics with a pry tool or replacing the entire door panel with the one from the Limited model?
The reason I ask is that I just searched on eBay and for the 5th gen the entire door panel is for sale on there.
Hacksaw
az
That's a good question. Toyota may only sell the full door panel assembly, not the two horizontal arm rest pieces separately (and possible a 3rd one, a vertical piece next to the lower horizontal piece). I was thinking just the 2 separate pieces, popped off with a pry tool. So it may be the case that only a 3rd party would make/sell these pieces.
AR1978
Chicago
Any updates on this for aftermarket?
I'll rest my arm on the top part of the door in my 15 Trail Premium which is soft touch there so it's a bit disappointing that Toyota put hard plastic there in the Off Road Premium models.
DangItsDen
Hayden
C'mon aftermarket vendors! You're leaving money on the table here. Take my moneyyyyy
Limited, Platinum, Pro and TrailHunter have the soft touch stuff. Haven’t heard of any aftermarket options. Just buying a higher trim level.
