What Gas Octane Level Required For iForce Max Hybrid - 87 or 91?
Cory39744
Cory
Virginia, USA
Maybe someone can explain to me what Octane goes into the IForce Max? The manual states 87 (research octane 91) or higher? So is it 87 or 91?
2025 2026 4runner 6th gen What Gas Octane Level Required For iForce Max Hybrid - 87 or 91? IMG_2041
zgreen
Zach
Hey Cory. Definitely a bit confusing! As for what I have been able to determine, it will take 87, but operates better on 91, with no ethanol. There are a few threads on here that talk about an additional 20+ horsepower and 20+ torque as well with the 91 or higher. That's all I got. Hopefully someone with a bit more knowledge will drop on in.
CO/ZA
Denver
25 4R ORP
87 AKI
91 RON
AKI is the measurement used by the United States, which is an average of RON and MON.
RON is used in the rest of the world as the standard.
I’d use premium 91/93 AKI in the US personally, as the turbo can take advantage of it and it’s not much more $.
Gumpus
US
So just to reinforce, your owners manual is recommending 87 octane in the US since it's the AKI number shown on pumps.
Whether you might want to use higher octane is another discussion.
CorvinoTRDPRO
Michael
Waverley, Nova scotia
2018 Jeep grand cherokee limited, 2025 4Runner Platinum
It’s a government issue also. Here in canada says 87 regular fuel
zgreen
Zach
That is correct! I am running 91 in my TD Pro as a personal preference, to get hopefully a little bit better, gas mileage as well as the extra house horsepower and torque.
EarthPIG_0311
The 90660
'25 4Runner Limited i-Force Max, '20 Civic Si
I look at it like this: 87 is the minimum. You're good to go with 87, no quarrel.
However higher is better. As proved by the dyno showing increased power.
Personally I only put 91. It's a turbo charged engine, I'm going to put the highest octane available and in CA, 91 is the highest I can find
CMill4Runner
Craig
CO
I run 89/91 whichever I can get here in CO in my 2.7L TT Bronco and you can really feel the difference in power and better MPG. When we get our Max in a month I'll see if the same applies to the T4R but my guess is it will for sure. I will also be curious how 91 affects MPG's.
6thGen1419
Peter
New Mexico
AI says better mileage with higher octane is a myth.
AI:
🔹 1. Higher octane ≠ more energy
  • Octane rating only measures resistance to knock (pre-ignition), not energy content.
  • In fact, higher-octane fuels sometimes have slightly less energy per gallon than regular fuel (differences are small, but measurable — usually 0.5–1%).
  • So if you put 91 or 93 octane in an engine tuned for 87, you’re not giving it more power; you’re just giving it fuel it doesn’t need.
zgreen
Zach
Well, you can either take a very easy AI search (which are incorrect a lot of the time) or dig in and look at the dyno tests that were done on this specific engine, which shows up to a 20 hp gain and better MPG... There is a lot of research out there and threads here on this forum, about this exact topic. 👍🏼
6thGen1419
Peter
New Mexico
You're right, but it requires tuning and ECU mods?
AI again:
Some dyno tests report up to 20 hp gain with 91 octane.
  • These tests are done under specific controlled conditions, ECU adjustments, or optimistic real-world dyno variations.
But look, I don't know what I'm talking about. I have no reason to trust AI more than you.
It's an interesting topic though.
zgreen
Zach
AI again:
Very much so! I haven't downgraded to 85 octane yet to see if I can get any anecdotal information, so I just know how it drives with the 91. Have a good one and enjoy your rig!
