theo
theo
Blk4runner1960
But the stock 20s are 8” wide
Yes they are . Those tire are at the minimum requirement. I feel comfortable in the middle at 9” .
My new rims will be 8.5” wide on 275/60/20
Morrison
Alex
Hickory, NC
2025 4Runner Sport Premium
Ok gotcha, do you think there will be any issues with those tires on the stock 20s having the minimum width?
theo
theo
Blk4runner1960
A salesman sold me a set of big tires . For my rim that were the minimum width . After 20,000 miles were the tread meet side wall. All the tires cracked like they were dry rotted . Tires to wide on a small width rim has a ballon effect look. My Tahoe was 6,800lbs pulling a 5,000lbs boat. The swaying of the vehicle left to right caused by wind could had contributed to it.This was 20 years ago on my Tahoe. The new technology,rubber , engineering of making tires has changed since then. You maybe ok with the minimum width
mideastbeast61
DFW
2025 4Runner TRD Sport Prem
Can I ask a dumb question. On both rear doors, is there a lot of play towards the top/back of the rear doors and vent windows (triangle pieces)? Mine does on both sides and I was curious if this was normal.
Vanessa
Hey, thanks for posting your pics. Your tires look badass! Are you still not experiencing any rubbing or anything? I saw that you said you were still going to get a lift, is that just because you want one or because you need more room for the tires? I'm in the market for new tires for my TRD sport as well but I'm not wanting to get a lift if I can get away with just new tires.
Gastan
Tacoma TRD Pro
Yep @samuelvelas says in the first post "No rubbing at all." ?
Ltd.Herit.'26
Austin
Dallas
2026 4Runner Limited 4wd
Put some beefy 285/60R20 Mickey Thompson Baja Boss tires on the rig. I believe it’s a hair over 33s.
No rubbing at all.
285:60r20 tires 2025 4runner TRD Sport factory wheels2.jpg
285:60r20 tires 2025 4runner TRD Sport factory wheels9.jpg
285:60r20 tires 2025 4runner TRD Sport factory wheels8.jpg
285:60r20 tires 2025 4runner TRD Sport factory wheels6.jpg
285:60r20 tires 2025 4runner TRD Sport factory wheels5.jpg
285:60r20 tires 2025 4runner TRD Sport factory wheels4.jpg
285:60r20 tires 2025 4runner TRD Sport factory wheels3.jpg
285:60r20 tires 2025 4runner TRD Sport factory wheels1.jpg
Update:
Just went in a trail called two towers loop in nj. No issues at all. Will definitely put westcott level kit in the future
Looks sick- were you able to get a full size spare mounted? No spacer? Limited wheels being 55 offset has me concerned they might rub, not sure what your offset is?
