IsGon26
Israel
Chicago Metro
2026 4Runner TRD ORP HV
Installed wireless version on my 2026 trd orp hybrid this weekend. Power from passenger side under hood fuse box, relay on driver side fuse box. Both boxes are soft plastic, so i drilled tiny holes close to the base where fuses lie out toward rear of vehicle. Cut the+ wire and slid through then added connector once in the fuse box, same for the relay wire-relay wire is a single wire so cut and slid through tiny hole then just soldered and used heat shrink tube that sits inside the fuse box.
Man Rome
Man Rome
Manrom
Cali
Man Rome
Man Rome
Manrom
Cali
Do you have any pictures and have you had any issues with the hybrid starting stopping
IsGon26
Israel
Chicago Metro
Is the fuse you pull the purple one?
Yes, its marked on the lid as ST
No issues whatsoever, here are a few pictures. I might add a dab of silicon just for safety, but the holes i made the wires went in very snug.
2025 2026 4runner 6th gen 41.22 Kill Switch on a 2025 4Runner hybrid IMG_0624
2025 2026 4runner 6th gen 41.22 Kill Switch on a 2025 4Runner hybrid IMG_0625
2025 2026 4runner 6th gen 41.22 Kill Switch on a 2025 4Runner hybrid IMG_0626
2025 2026 4runner 6th gen 41.22 Kill Switch on a 2025 4Runner hybrid IMG_0627
Man Rome
Man Rome
Manrom
Cali
Very nice thank you for the pictures
TMLifer
US
What size drill bit did you use to make the hole?
PdlMnk
6G4R - TRD ORP Premium Hybrid
FYI 41.22's own site says this doesn't work with the hybrid, for anyone wondering like I was.
@IsGon26 - Does it actually stop the4runner from starting?
PdlMnk
4122 absolutely works with the hybrid.
So I wonder what they are talking about, then?
From their website:
Our Kill Switch is not compatible with your 2026 Toyota 4Runner Hybrid (i-FORCE MAX).
The 2025-2026 4Runner i-FORCE MAX hybrid has its starter circuit integrated into the vehicle's electronics — there is no removable starter relay our kit can interrupt, so it cannot effectively immobilize this vehicle. If you instead have the non-hybrid gas 4Runner, please select "4Runner (Gas, Non-Hybrid)" — our kit fits the gas engine.
Have questions? Contact Us and our team will do our best to help.
PdlMnk
I know they are wrong because I have a hybrid and use their product, so ….
Well, it's hard to argue with the company who makes the product. Maybe there is a path that the kit doesn't cover?
mfoga
r4unner
I am thinking one of two things, we have not tested it so we wont confirm is works or there is a way to bypass it on a hybrid so it doesn't work. I am leaning towards first option as that is very common. Look at home many parts Toyota says wont fit or may not fit on the 4runner because it didn't come stock or as an option.
