Crash Plate Removed From Driver Side - Photo Request
Rock Doc
Joshua
Alexandria
2025 TRD Pro and 2002 Tundra
Can someone please send me a picture after the driver side crash plates have been removed. There is one piece that is holding some kind of wiring on the driver side and mine looks like it is bent or out of place the passenger side is clean after removal of plates. I am getting tire rub on the driver side when turning just want to compare.
Thank you!!
Rock Doc
Rock Doc
Joshua
Alexandria
Thank you this confirms that lower piece has moved on me and is bent are you getting any rubbing with the piece with the wiring and two bolts, do you know what the wiring is for?
It appears that my TRD ORP does not have that wiring (see photos), so I hypothesize that it is related to the SDM (which I regret not having after the comparison of our relative success on that obstacle this weekend:>)
Crash bracket delete middle of install:
2025 2026 4runner 6th gen Crash Plate Removed From Driver Side - Photo Request 20251002_204402
2025 2026 4runner 6th gen Crash Plate Removed From Driver Side - Photo Request 20251002_205533
Crash bracket delete install complete:
2025 2026 4runner 6th gen Crash Plate Removed From Driver Side - Photo Request 20251002_205538
No rubbing but if yours is hitting it looks like it only has 2 bolts to remove to be able to modify it to make clearance.
Rock Doc
Rock Doc
Joshua
Alexandria
Thanks Mike will loosen and put back in correct position looks like a hammer swing will bend it back.
Rock Doc
Rock Doc
Joshua
Alexandria
I think I can adjust it not sure if I want to take it off since it has that wiring attached to it will evaluate tomorrow have to do an oil change at dealer so will ask them to take a look thanks for the feedback.
