What AI has to say about Limited Tire Sizes
Blackie1
Paul
2026 4Runner
Here's my AI question:
What are the largest tires I can put on a 2026 Toyota 4Runner limited four wheel drive without having to make any modifications to the vehicle?
GroK:
For the 2026 Toyota 4Runner Limited 4WD (6th gen), the stock tire size is 265/55R20 (approximately 31.5 inches in diameter) on 20x8" wheels with +55mm offset.
The largest tires that typically fit without any modifications (no lift/leveling kit, no trimming, no removal of mud flaps/crash plates/splash guards, and ideally on stock wheels or equivalent +55mm offset 20" wheels) are in the 275/55R20 to 285/55R20 range (roughly 32–32.3 inches diameter). These provide a modest upgrade in width and/or diameter while staying within stock clearance.
Key Details on Fitment (No Mods)
  • Stock setup: 265/55R20 (~31.5" diameter). Direct fit, of course.
  • Safe larger options on stock 20" wheels:
    • 275/55R20 (~32.0–32.3" diameter): Common upgrade. Many owners report no rubbing on similar 20" wheel trims (e.g., TRD Sport/Limited). It adds width for better looks and slight off-road traction without issues.
    • 285/55R20 (~32.3" diameter): Listed as a no-rub option in fitment guides for Limited/Platinum on stock suspension and +55mm offset wheels. Wider footprint but similar overall height.
  • 275/60R20 (~33.0" diameter): A bigger jump that may fit with minimal or no rubbing on stock setup for some, but it often requires checking (e.g., possible light contact at full steering lock or compression). Mud flap removal is sometimes noted as helpful, though that's a minor non-permanent change.
ChatGPT:
For a 2026 Toyota 4Runner Limited 4WD with the factory 20-inch wheels, the OEM tire size is 265/55R20.
If your goal is the largest tire you can run without any modifications (no lift, no trimming, no spacer, no liner relocation), here's the practical guidance:
Tire SizeDiameterFits Stock?Notes
265/55R20 (OEM)31.5"âś…Factory size.
275/55R2031.9"âś…Best "plus-size" option. Slightly wider and taller with very low risk of rubbing. Speedometer changes by about 1%.
275/60R2033.0"âš  MaybeSome owners report success on the new 6th-generation 4Runner, but clearance depends on the tire model. It's not something I'd call a guaranteed no-modification fit.
285/55R2032.3"❌ Not recommendedWidth is usually the issue. Likely to rub at full steering lock or during suspension compression.
My recommendation
If you want zero hassle, go with:
275/55R20
This is generally considered the largest "safe" upgrade that:
  • Doesn't require a lift
  • Doesn't require trimming or moving the fender liners
  • Retains good on-road manners
  • Fills the wheel wells a little better
  • Causes only about a 1% speedometer difference
If you're after a more aggressive look
A good choice would be:
  • 275/55R20 BFGoodrich All-Terrain T/A KO3
  • 275/55R20 Falken Wildpeak A/T4W
  • 275/55R20 Toyo Open Country A/T III
  • 275/55R20 Nitto Recon Grappler A/T
These provide a beefier appearance while still staying within a size that's much more likely to clear on a stock Limited.
One thing to keep in mind is that tire model matters almost as much as tire size. Two tires with the same printed size can differ by more than half an inch in actual width or diameter, so an especially aggressive mud-terrain may rub where an all-terrain in the same nominal size does not.
If your goal is to make the Limited look closer to a TRD Pro while keeping the factory suspension and wheels, I can also recommend the tire that gives the most aggressive appearance without introducing rubbing issues.
Gemini:
The 2026 Toyota 4Runner Limited 4WD comes from the factory on 20" Ă— 8" alloy wheels with a +55mm offset wrapped in 265/55R20 tires (~31.5 inches in overall diameter).
Because the 6th-generation 4Runner shares Toyota's TNGA-F truck platform with the Tundra, it has roomier wheel wells than previous generations. However, the Limited’s factory +55mm high-offset 20-inch wheels keep the tire tucked in close to the inner suspension components and fender liners.
Max Tire Size Fits by Category (Factory Wheels & Stock Height)
1. The Safest Max Upgrade: 285/55R20
  • Overall Diameter: ~32.3" (+0.8" taller than stock)
  • Tire Width: ~11.2" (+0.8" wider than stock)
  • Fitment: This is the most reliable "plug-and-play" upgrade on factory Limited 20-inch wheels. It provides a meatier, wider stance without rubbing on the inner fender liners or suspension arms at full steering lock.
2. The Tallest "No-Cut" Option: 265/60R20
  • Overall Diameter: ~32.5" (+1.0" taller than stock)
  • Tire Width: ~10.4" (Same width as stock)
  • Fitment: Adds roughly half an inch of ground clearance. Because it maintains stock width, it clears internal components easily, though tire tread choice (aggressive all-terrain sidewall blocks vs. highway tires) can affect full-lock clearance near the front mud flap.
Key Things to Keep in Mind
  • Speedometer Calibration: Moving from a 31.5" tire to a ~32.5" tire will make your speedometer read roughly 2–3% slower than your actual speed (e.g., indicating 60 mph when traveling ~61.5 mph).
  • Downsizing Wheels for Off-Roading: If you intend to take the 4Runner off-road, many Limited owners choose to swap down to 17" or 18" aftermarket wheels. With a 17" or 18" wheel in a +25mm to +35mm offset, you can easily run a true 33" tire (like 285/70R17 or 275/70R18) on stock suspension with no rubbing or minor mud flap removal.
the biggest problem will be wheel offset if you dont use oem wheels.
most aftermarket wheels dont usually get above 25-30 offset but most i see are 20 offset. its a big difference when you visualize it with tires and wheels vs the oem tires and wheels
using my platinum oem wheel and tire specs and wanting to put aftermarket wheels and tires
1. first did a lookup of oem specs
https://www.wheel-size.com/size/toyota/4runner/2025/
2. then used the visualizer website to see how the poke changed with aftermarket wheels based on the specs
https://www.willtheyfit.com/
2025 2026 4runner 6th gen What AI has to say about Limited Tire Sizes 1784664723548-f
here is a different reference site to use besides the ones above
https://tiresize.com/
  • Like
Reactions: C/G
C/G
Cary
Orange County, CA
Nodak - any issues with mud flap, assuming you have them.
not any with the oem mud flaps (on our 23 tundra). but i kept the same tire specs just different aftermarket wheels.
i havent purchased the wheels yet for the wife's 4R, waiting until we get the vehicle in the driveway before i order the wheels. not going to replace the oem tires just yet since toyota changed from the grandtrek pt5a to a different tire now on the platinums
  • Like
Reactions: C/G
here is the 23 tundra after we put fuel flame wheels with duratrac's on them
oem mud flaps vs some rekgen mudflaps
you can see the added poke of a smaller offset than the oem wheels had. the oem wheels sat within the wheel well vs these flames at 20 off set, they poked about 1 inch past the fender flares.
2025 2026 4runner 6th gen What AI has to say about Limited Tire Sizes 2023 Tundra Mudflaps Rekgen Front 1 (resized)
2025 2026 4runner 6th gen What AI has to say about Limited Tire Sizes 2023 Tundra Mudflaps OEM Front 1 (resized)
  • Like
Reactions: C/G
C/G
Cary
Orange County, CA
Looks great. As always, helpful feedback. Appreciate you and your forum feedback. I imagine being in ND mods to deal with the weather drive a lot of your decisions.
weather plays a bit but now that the wife is moving back into the garage (23 tundra didnt fit) with the 4R and now has FT4WD vs the tundra PT4WD, she will be happier.
i can do most easy DIY mods that dont involve bodywork or electrical. dont really have good dedicated off road shops to do work here and the one's we do have, i wouldnt trust.
if it came down to any major work, i would drive down to an oem and have them install it (ie: stealth bumpers, etc)
my location restricts a lot of options i can do, even buying vehicles (i would love to buy a lexus, but the nearest dealer is 500 miles away and after talking with lexus financial, any warranty repairs would have to done at a lexus dealer, yeah thats not happening as its a day drive 1 way, overnight stay, drop off in the morning, wait a day at most, and drive back another day. so its a 3 day vacation i have to take to even get anything done)
and the funny part is some of the threads that are posted. they dont even impact me since due to winters, it alters they way we do things here.
mpg thread, kinda pointless since we have cold/windy all the time so i/we get junk mpg do to either head winds or tail winds
we dont worry about how poeple worry about getting another 1-3 gal of gas into a tank. winters here dictate we dont try to get below 1/2 or 1/4 tank. safety wise we keep a reserve in the tank since if/when we slide off the road or something happens, we have enough gas to keep us warm waiting for help or a tow out of a ditch.
and having up to -30F temps kills our mpg in the winters due to all the remote starting, our mpg drops down in the low 10's or even single digits depending on how many remote starts we do during a tank.
i just track the mpg as a gee whiz fun stat, it doesnt alter how we drive or anything. we fill up and just drive.
jcash25
jason
Houston
2025 TRDO Premium
We are really doing this? smh literally arguing over what Ai says
Dead Horse
Oklahoma
Especially when that AI is getting its answers from forums and Reddit. Give it a little time, rerun that query, and it will 100% reference THIS VERY THREAD.
