Running board options
TYMBO
Tim
IL
2026 4RUNNER
Does anyone make a bracket to lower the stock running boards about 3 inches?
The stock location is a little too tall for my wife.
get.outside.75
Brian
Charlotte
Limited iForce max
Wait sliders that mount to the same spot as the running boards? Don't the running boards mout to the body and the slider should mount to the frame. Unless you are replacing the trailhunter sliders then yes it would be same.
The running boards attach to the body, the Westcott sliders attach to the frame.
2025 2026 4runner 6th gen Running board options 1784660859299-rc
wouldnt work since the movement of the boards is dependent on travel distance of the automatic boards from toyota.
if you extended the reach, then they wouldnt sit flush with the body anymore when retracted
and i am pretty sure the oem boards are not adjustable for reach and retraction adjustments.
your best bet would be aftermarket, but i am not sure they are adjustable for reach/retraction
TYMBO
Tim
IL
2026 4RUNNER
I have the fixed running boards not the retractable ones. Sorry if I am not using the correct terminology.
