Small Crack Discovered While Doing Oil Change
Snaker
East Coast
2003 4Runner
I was doing my routine 6 month oil change when I saw that there is a crack on one of the components next to the oil drain plug. To make sure it is not just debris, I ran my finger over it and confirmed it is a small crack. I am unsure about what this part is, so I circled the same part from a "The Car Care Nut" YouTube video for reference.
Is this something that I should immediately bring to the dealer to get replaced, or is it safe to postpone?
Thank you in advance.
2025 2026 4runner 6th gen Small Crack Discovered While Doing Oil Change IMG20260707151302
2025 2026 4runner 6th gen Small Crack Discovered While Doing Oil Change Screenshot 2026-07-15 214416
yes warranty ...[unless you've been out jumping it]
that is the front axle tube coming from the front differential
and that is a huge, extensive crack
vehicle should not be driven at all, needs to be towed
possible life safety issue if that breaks while driving
Snaker
Snaker
East Coast
2003 4Runner
Ok, I will schedule an appointment to get this replaced asap. This car only has 1.5K miles so this was unexpected. Thanks!
HVLA
Lexus
Wow. I wonder if that is some kind of casting defect? It should take a tremendous impact to crack that.
yeah super unusual. that has to be a one-off defect.
if that is systemic, there will be a giant recall.
that is a single assembly, so it is your front differential that is cracked.
the cracked axle tube is part of the single unit
2025 2026 4runner 6th gen Small Crack Discovered While Doing Oil Change fd
Are you sure it’s a crack and not just a casting mark?
it's gotta be a crack
though it could be a casting mark, I've never seen a casting
mark like that on any drivetrain component on any toyota
I'd be surprised if it isn't a crack...and if it is a casting mark, then others
here could peek at the front diff and see what theirs looks like they'd
have a similar 'casting mark'
Snaker
Snaker
East Coast
2003 4Runner
You guys should all check to see if you have the same issue before the warranty expires. If I had brought the vehicle in to the dealer to do the oil change, I wouldn't have caught that issue until it was too late.
Let us know what they say!
xp0nex
2025 4Runner ORP
Next time I get under there I'll have to take a look
Snaker
Snaker
East Coast
2003 4Runner
Update: So I went to the dealership and they asked me to point out the area where the crack is. I showed them and they called over 2 master technicians to examine that area. They determined that it is a casting line since most cracks start at the edge of the part and not the middle. However, I don't believe them because a casting line is supposed to bump out and not dent in and have a bunch of cracks splitting off from the main crack. Can someone please take a picture of their component so I have proof that my vehicle has an issue (or proves that it is indeed a casting line)?
2025 2026 4runner 6th gen Small Crack Discovered While Doing Oil Change 1784227957774-mk
crawling under mine asap to check it...[a few hours]
If it has similar defect will post pics
