Ticking Sound Coming From Dash Near Windshield
Yetirunner9
Hello, I have a 2025 ORP with around 10K miles and it has developed a loud ticking sound coming from around the dash where it meets the windshield. I have tried isolating the source but have not been aboe to get to it. Anybody else have this issue? Tends to happen more or be louder when it is hot outside. Sort of sounds like metal ticking. Happens whenever the car is moving above a few MPH.
most likely a clip under the dash, or most likely a plastic panel is rubbing.
had this happen on our 2016 taco, the speaker cover was rubbing in the corner.
funny pic of me putting some toothpicks in the corner to isolate the sound and fixing the issue.
eventually added some rubber felt along the base to give the 2 plastics and easy way to flex without making noise
2025 2026 4runner 6th gen Ticking Sound Coming From Dash Near Windshield 1755522890118-2s
Rbaz
Rory
2025 4RUNNER
Imhaving the same issue. Did you fix?
mcnuggs
4Runner TRD PRO
Want to revive this as I'm experiencing the same. Going to do some more experimentation this weekend, but something I noticed that the heat shield under the hood was missing some clips (like they literally fell out lol). When looking further, the windshield wiper fluid hose is fed from the driver side and under the heat shield. I almost suspect that the hose is hitting the bare metal under the heat shield and causing the same exact noise you have in your video.
Regardless, very curious to know if you found a fix to the noise @Yetirunner9
TRDBROG
NV
4R TRD PRO
Did you end up figuring this out by chance?
Tasc
2025 4Runner SR5 4x4, 2025 Tacoma TRD 4x4
I'm having this same issue, almost sounds like a styrofoam cooler lid vibrating right under windshield. Funny thing is I installed a hood insulator before this started and was sure that was the noise, so I ripped it out. Turns out, that wasn't it at all. I'll check the hood prop and see if its loose, thanks for the tip.
TRDBROG
NV
4R TRD PRO
I checked the hood prop too and resolved the loose end, but that did not resolve the issue.
The way you described it as a cooler lid vibrating is spot on!
