Is 0w20 adequate for south Florida Climate
FloridaPhotog
Jon
SW Florida USA
2026 4Runner
Vehicle 2026 Non-hybrid
This is the third oil change since new. The 1st one was at 431 miles, 2nd at 2899 and I just did the 3rd one at 5180 miles. What was shocking was how dark the oil was with only 2281 miles on it. Considering the oil is 0w20 and living in south Florida where the ambient temperature averages over 90 degrees, I'm wondering what the oil shear capacity is at 2281 miles. I saved a sample and sent it off to Blackstone Labs. Of course I'll post the results.
Whats everyone thoughts and experience with high temperatures and 0w20?
Also, my driving habits generally are 60% around town ( not a lot of stoplights ) and 40% highways ( average speed 75 mph - Florida is raising the interstate speed limit to 80 in a few months ).
Note- this is a 2026 I sold the 2025 and can't change it in my profile.
drNick
Nick
Ft. Myers, FL
Use quality oil with high TBN and you’ll be fine. Here in Florida we can run 5W20 all year long as well. 5W30 after the warranty is up.
SouthCoast
Kingwood
2025 4runner TRD ORP
I'm in Houston and switching to 5w30 in 300 miles. I've run uoa's and am unsatisfied with the shear after only 2200-2400 miles, three times. Was it still in grade? yes, but not with enough margin for my satisfaction. No, fuel dilution was not a contributing factor. Given that winter temps are almost never going to reach 0w lows, a 5w is completely fine in Florida. 0w can work fine, especially for warranty work, but not necessary.
Gumpus
US
My experience working for an OEM as both a powertrain and vehicle engineer is that your vehicle was designed for 0/20 and the design was proven using 0/20. Where I worked the hot weather testing included trailer towing up Davis Dam, 300 hours at wide open throttle on a dyno, and testing in LA city traffic. We had a track in S FL but southern Arizona is a more severe environment for hot weather durability testing so most OEMs do testing there.
I think you'll be fine if you want to run a slightly different weight for whatever reason but I'll stick with factory recommended weight since it's the only proven weight. Your vehicle uses it's oil for cooling and variable valve timing actuation as well as lubrication and even just looking at lubrication I'm not at all convinced that heavier oil is better for lubricating all components. Heavier oil means more friction and more friction means more heat. I've seen engines torn down after 200k miles that show virtually zero wear. Use a good synthetic and change it once in a while.
neomist26
justin
Memphis, TN
Interesting question by the OP.
I find these responses amusing. If we all could refrain from antidotal guidance and provide more empirical information, it would certainly help the entire community.
