EverydayFred
Fred
Las Vegas
2025 SR5
I installed the CarTrimHome 14.6" headunit upgrade this past weekend and thought I would document this process on my YouTube channel. They also gave me a 10% discount code to share, so feel free to use discount code FRED.
2025 2026 4runner 6th gen Installed Aftermarket 14 Inch Screen Head Unit Upgrade (CarTrimHome C12) CTHome Screen Installed
How to Install:
This is pretty much plug-and-play so the install is relatively easy. There are a lot of wires so don't feel intimated. All connectors on the factory unit can only fit into its specific plug so there is very little chance of doing it wrong.
2025 2026 4runner 6th gen Installed Aftermarket 14 Inch Screen Head Unit Upgrade (CarTrimHome C12) Trim Removal
First thing you will want to do is pop off the trim piece right in front of the factory radio. You can use the provided trim tools to wedge and pop off the trim.
2025 2026 4runner 6th gen Installed Aftermarket 14 Inch Screen Head Unit Upgrade (CarTrimHome C12) 10mm Bolt Removal
Next, remove the (4) 10mm bolts that attach the factory radio to the dash. This is the only step that requires tools, use a 10mm socket for removal.
2025 2026 4runner 6th gen Installed Aftermarket 14 Inch Screen Head Unit Upgrade (CarTrimHome C12) Factory Radio Removal
The factory radio will then slide right out. I would suggest placing a small box over the shifter so you have a flat surface to set down the radio without creating an scratches on the radio or your dash.
2025 2026 4runner 6th gen Installed Aftermarket 14 Inch Screen Head Unit Upgrade (CarTrimHome C12) Factory Radio Plugs
You can now remove all plugs and connectors from the factory unit. Again, these connectors are all different so there is no way to plug incorrectly.
2025 2026 4runner 6th gen Installed Aftermarket 14 Inch Screen Head Unit Upgrade (CarTrimHome C12) Main Power Harness
NOTE:
The CarTrimHome 14" screen comes with 2 MAIN Power Harnesses but you only need to use one. I was able to use the harness labled "Toyota Camry". You can then start connecting the aftermarket harness to the factory wire connectors.
2025 2026 4runner 6th gen Installed Aftermarket 14 Inch Screen Head Unit Upgrade (CarTrimHome C12) Installing CTHome Screen
I go over some of the wiring in my YouTube video but the manual that comes with the head unit also shows you where to connect each plug into the aftermarket head unit. Again, this is hard to mess up since each plug is different.
2025 2026 4runner 6th gen Installed Aftermarket 14 Inch Screen Head Unit Upgrade (CarTrimHome C12) Two Mounting Bolt
When bolting the aftermarket head unit back to the dash, you only need to use TWO of the factory bolts instead of FOUR.
Here are some shots of the UI and Apps:
Everything worked as it should and I haven't had any issues. I did need to make some setting adjustments but I go over that in my video.
  • Steering wheel controls - âś…
  • Wireless Apple Carplay and Android Auto - âś…
  • Reverse camera display - âś…
  • Google Playstore (tons of apps) - âś…
  • Watching video (YouTube, Netflix, HBO, ect) - âś…
NOTE:
You may notice there is no volume knob, I did talk to CarTrimHome and they showed me a prototype of the volume module they are working on which would be installed in the same location as the factory 14" screen volume knob. But the knob is not really necessary since the steering wheel controls work and you can also use gestures on the screen. A two-finger swipe up or down will raise/lower the volume
2025 2026 4runner 6th gen Installed Aftermarket 14 Inch Screen Head Unit Upgrade (CarTrimHome C12) CTHome YouTube Player
2025 2026 4runner 6th gen Installed Aftermarket 14 Inch Screen Head Unit Upgrade (CarTrimHome C12) Apply Car Play
2025 2026 4runner 6th gen Installed Aftermarket 14 Inch Screen Head Unit Upgrade (CarTrimHome C12) Backup Camera Display
Overall I am very satisfied with this head unit and its a huge improvement over my factory 8" radio.
Don't forget about the 10% discount using code FRED if you decide to upgrade to the CarTrimHome C12 head unit.
YanMik
Ian Escala
2025 TRD Offroad 4 Runner (Soon)
Will this have the capability of provides 360 camera views?
jcaluya27
Julius
MO
4Runner SR5
Did they give you an ETA on when the volume knob will be available? I’m interested in this product. Thanks for the write up and install video. Kudos.
HVLA
Lexus
Do they have plans to offer one of these for a 3rd gen tundra? 2022-2026?
EverydayFred
EverydayFred
Fred
Las Vegas
2025 SR5
I didn’t get an ETA
sfigueroa
Sven
2026 4Runner
Great video!
The specs say 45 watts per channel, whereas a quick Google search says the stock SR5 system likely has "up to 25". Do you notice a difference? After buying this head unit, would it make more sense to do the speaker upgrade/sound deadening as well?
I followed your FitcamX video to do my dash cam install and that went very well (though it took me 10 minutes to stuff all of the wires back in). It's been great.
BomPho
california
4runner 2025 SR5
Any delays in the Apple Carplay connection when the car is starting?
Been following your mods on YouTube, you're killing it.
20119mm
Donnie
East Tennessee
2025 Toyota 4Runner Platinum
I already have the 14” display in my 4Runner, but if I didn’t I’d be all about this! Very nice!
