zeja0331
Toronto
Toyota 4runner 2026 TRD Sport
Hopefully this helps someone. I know I wasted a lot of time worrying about tire size, offset and the potential for rubbing without a lift.
Faliken Wildpeak AT4W C rated 285/70/17
Method 703, +35 offset
No rub, no issues everything stock.
Thrilled with how it turned out. Exactly the look I wanted. Aggressive, thick look and minimal poke.
Just won’t pay attention to fuel economy 😏
2025 2026 4runner 6th gen 285/70/17 Wildpeak AT4W, +35 offset Method 703, no lift, no rub (photos) IMG_7598
2025 2026 4runner 6th gen 285/70/17 Wildpeak AT4W, +35 offset Method 703, no lift, no rub (photos) IMG_7599
2025 2026 4runner 6th gen 285/70/17 Wildpeak AT4W, +35 offset Method 703, no lift, no rub (photos) 285:70:17 Wildpeak AT4W, +35 offset, no lift, no rub (photos)
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
Doing same set up but with +25 offset. Do you think that will work?
zeja0331
Toronto
from all i read, it should.
i didnt wanna risk it, and i prefer this look, but if you want more poke, might be worth looking into
mcd_ovrlnd
SE PA
how do they drive? Do you notice the weight difference? That’s the only thing I struggle with on the Falkens. KO3 is like net net 8 pounds lighter for me on each tire but not as great on wet traction from what I hear.
zeja0331
Toronto
coming over from a wrangler, I find this car even with the bigger tires drives much smoother. I’m very happy with it. Here in Canada, I need good traction on wet/snow so they’re great for me.
Blackie1
Paul
2026 4Runner
How did you manage the different hub size on the new 4Runners going to the 95.1?
zeja0331
Toronto
the guy i ordered the wheels/tires thru, ordered me gorilla hub rings 106.25 to 95.1
