Fog Light Replacements, what's out there? Need some help fam
jlostetter
Jared
6th Gen, Limited, i ForceMax, Pearl
Hello everyone. I'm waiting on my Limited/MAX/ Pearl white to arrive in November. This will be my 4th 4runner. I've been out of the Toyota game since my 2014 Trail Premium. One thing I'm looking forward to doing as a first mod is replacing those cheap looking(and non effective) fog lights. Anyone have recommendations? I've been looking at the CaliRaised, Rigid etc. Prices all 200-700 ish. White or amber? Also, I want some great output but nothing needed for major trail or off road situations. I just want a better light without going too crazy and for better daily use. Appreciate any feedback.
Franco
Frank
San Clemente, CA
2025 4Runner TRD Off-Road
I went with the Baja Designs S2 Sport Light Kit that is a direct replacement for the standard fogs.
They are a definite improvement over stock for sure! I installed them myself which is simple but a little time consuming since you have to remove the bumper cover.
I would highly recommend adding the four Squadron Lights (See pic) at the same time so you don't have to remove the bumper cover again like I did.
2025 2026 4runner 6th gen Fog Light Replacements, what's out there? Need some help fam IMG_3763
Twisted
5th Gen TRD -> 6th Gen TRDORP
I did the Baja Design S2's but didn't use their direct fit kit. I bought the lights standalone and used the Westcott mount. Gives it a much cleaner and more finished off look. You can order the Baja Design Y harness to make life simple and then make your own conversion harness to plug directly into the factory plug so no cutting of the factory wires. (I did a little different as I wired to an SPOD BantamX using the factory harness as an input trigger but that isn't necessary. I wanted full control on the SPOD so they stay on with high beams and adds strobe features.)
2025 2026 4runner 6th gen Fog Light Replacements, what's out there? Need some help fam DSCF2129
williams23
Marvin
2025 4Runner SR5 Heritage Blue
Pardon my ignorance, but do you have a link to the exact splitter you used for the fogs?
Such a good choice too! Looks good.
Jaxsin310
Jack
2025 4runner TRD PRO
what do you mean by the westcott mounting brackets give a cleaner look? I have the Baja lights with their mounting bracket but if Westcott is cleaner, I will order their bracket.
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
Same
mcd_ovrlnd
SE PA
The Wescott bracket sort of fills in the gaps that the Baja bracket creates. See pic.
2025 2026 4runner 6th gen Fog Light Replacements, what's out there? Need some help fam IMG_8815
