Rough Country Power Running Boards released
Formidable
Bellevue, WA
2025 TRD Pro
Looks like rough country released their power running boards for the 6th gen. Anyone have these installed? Amp research is still dragging their feet. Which is sad considering it’s a product that reuses the same mounting points as the Tacoma… just shorter boards. Still can’t order OEM power boards allocated for the platinum and limited trims so aftermarket will have to do.
https://www.roughcountry.com/product/ht-series-power-running-boards-esr70900
4R-Sport
Kevin
PA
Good spot! I've been checking most manufacturers almost weekly for power running boards to become available. I am not necessarily going to pull the trigger and purchase anytime soon, but I look forward to more options becoming available.
ekvlimited
Atlanta
4Runner Limited 2026
I'd like to purchase a set, but they don't have pictures of what they look like on the 4Runner. Guessing nobody does at this point since they are new? Just wondering if they were designed for the 4Runner, or just a bolt on generic power step?
Cranberry
Manitoba Canada
Interesting to see this. Ill have to see how they perform after a full winter.
I ran a similar system on another truck 10 years ago and had to take them off because snow slush would spray up on them while driving and then freeze, locking the running boards in and sending fault codes every time i stopped.
4R-Sport
Kevin
PA
I do not have any experience with power running boards (outside of a rental once), but I also have the winter concerns. It is understanding that some models have gotten better over the years in handling snow/ice conditions with design changes and by adding additional motors (2 per side instead of one per side).
Hopefully other options start to surface as I would really like to see them on a 6th gen before making any type of decision.
Joestac
Curious what you mean as they have a ton of pictures on the link provided with them on a 4Runner.
4R-Sport
Kevin
PA
Are you referring to 3rd party options or the OEM's that are only available and work with the limited & platinum 6th gen models. There's a difference!
Joestac
4R-Sport
Kevin
PA
Formidable
Formidable
Bellevue, WA
2025 TRD Pro
Dead Horse
Oklahoma
Dang. That's not even a bad price either.
I've had the AMP steps on my Tundra for 13 years, and had zero issues.
Formidable
Formidable
Bellevue, WA
2025 TRD Pro
I am aware there are plenty of examples on the 5th gen. I considered the AMP for 2021 ORP, but never pulled the trigger prior to trading.
Sorry. Misread your post and got “trims” and gens mixed up. My original post inquired if anyone has these installed on the 6th gen yet. Obviously someone owns the model 4runner used for the demo.
