mfoga
r4unner
The most useful thing I didn't know about was the fact you can stop the liftgate with pushing the open button again.
mfoga
r4unner
The wiper I kind of knew because omy previous car I had to do that to pull wipers off windshield because they were tucked under the hood. I started to find it worked on a lot of cars even that didn't need it like the 4runner.
Cranberry
Manitoba Canada
Some good things in there
Cranberry
Manitoba Canada
Also, he missed a lot of other good things as well.
1) holding unlock on remote key fob rolls all windows down
2) holding lock on remote will command start the truck without your phone.
3) holding the gas pedal down to the floor and then shifting from neutral to drive will grenade your transmission.
Neat little secrets toyota hides in there for everyone.
4cyl_runner
Rick
Arizona USA
Tacoma TRD OR, 2026 4Runner
I was looking on the menu to change the setting (rear door to open with the front) , but it seems toyoda removed that setting
Cartierusm
Carter
San Francisco
2025 4Runner i-Force Max Off Road Premium
That setting is still there. I have it set that way on my 2025 4R. It's a menu item on the main screen not the speedo cluster.
did the video mention you can close any or all
open windows within 30 sec after shutdown and
key removal ?
Larry-O
Larry
Goffstown
key removal ?
I didnt hear that one. How do you close all open windows after shutdown?
before you leave the vehicle, but if you've already shut everything down,
just operate the window switches, they remain operational for
about 30 seconds...so if you forget to close them you can do it
w/o having to use key or start button to give them power
if you do start to raise one or lower one, and the 30sec time frame
passes while operating it, the window will stop where it is and not go all the way
RogueWarrior65
Blair
It's too bad that there isn't a way to lower all the windows about 2 inches.
