Qbania
Q
Victoria
2025 4Runner TRD Pro
Hey guys. I've watched this video(raptor light install vid) a few times, I'm about to pull trigger and order, but there's quite a few neg. reviews about a light burning out here n there, a couple after a few months... is this a solid product? I'm interested to hear positive reviews, as most of the time it's just neg. reviews on Amazon (I'm searching these keywords on Amazon --> not adding a link on here -> "4Pcs Amber Grill Lights for 2024 2025 Toyota Tacoma LED Grille Marker Light 4th Gen Tacoma Accessories Front Bumper Raptor Lamp"
papadop88
papadop88
7K miles and a few months so far and all is well. I'm happy with them. They're cheap. Something happens, order another one. I have an extra set sitting in a cabinet just in case.
Qbania
Q
Victoria
Thanks for the tips…
2025 2026 4runner 6th gen Papadop88's Underground 2025 4Runner TRD Pro 6th Gen Build IMG_0358
edawg
hawaii
4runner PRO
Can u take a true side shot of ur pro with these 35’s? Im about to pull the trigger on the Wescott lift and wanna make a final decision on installing tophat or not. Thanks
YanMik
Ian Escala
2025 TRD Offroad 4 Runner (Soon)
For the rock sliders from Wescott, did you have to Rim the holes to make them bigger on the underside of the frame?
papadop88
papadop88
Nope. The Pros and THs come pre-drilled.
papadop88
papadop88
You have to drill out the front to 11/16" and the rear 5/8" to accept the rivnuts.
We didn't have to do anything but screw them in. They were pre-drilled.
YanMik
Ian Escala
I’m seeing the pattern that ORP and ORNonP do not have threaded rods and would have to be rimmed and Box Bolted
I believe you may be confusing the side of the frame, that's where they are predrilled and some prethreaded, YanMik is talking about the underside of the frame.
Not sure about 26' models but some trims had the prethreaded holes on the side and some didn't in 25'..
acropora
2026 4runner
@papadop88
has the front end settled more on the collars? wondering what the hub to fender difference is now that you've got some miles on the setup without the top hat..
papadop88
papadop88
@papadop88
Hasn't settled much if any from when it was lifted. Mind you when I took those measurements, the lift was already on there for over a month and was driven several hundred miles. It had already settled.
acropora
2026 4runner
Good to hear, I'll likely be going the same route. Wish they sold the kit without that top hat..
