talmadge
Timothy
SLC, UT
Interesting idea. I don't KNOW that this would work but based on photos posted here (including one I took) I wonder if one could slide the control panel "around the corner" of that trim piece. This would position all the connectors (both air and electrical) in roughly the same place but make the panel accessible from the back rather than side of that wheel well panel. I suppose whether this helps would depend on the design of the drawer system but for me (without a drawer system) it would still help avoid other cargo I often have stacked up in that location. Am interested in others takes on this...
Clean photo showing TH (not mine) panel location, and "empty" spot between that and the speaker:
Photo of my scratched up cargo area with cover of that panel off - there might be space behind that wall to the right IFF the panel would fit there.
Yep, I've wondered if it would be possible to cut my own hole "around the corner" there facing back, and it would definitely be a lot more easily accessible if I did, or by mounting it facing vertically in that little cargo tray directly above the factory location. Is it possible to remove the cargo tray trim piece without removing the entire piece it's attached to? Or do those types of clips need to be accessed from inside?
Ideally I would have it in the location I previously described, marked by the arrow in this picture, which would be all the way in the back in the storage location behind the hybrid battery, but the other two options seem like they might be possible while still using the factory wiring and hose, and there may just not be enough space between the battery and the trim to cram the access panel in there. It would just be so nice to open the back and have the compressor always easily accessible.. Even before I installed the drawers I already felt like it wasn't in a great spot. It's a pretty nifty OEM addition but if I could pick and choose I'd probably trade it for an ARB 100% duty cycle compressor. Mine has had issues finding the right PSI (it will see-saw inflating and deflating) and overheating. On one occasion I had to give up on one tire and just go to the first gas station I could find because for some reason it could not get a consistent pressure read on that tire and refused to inflate it.
2025 2026 4runner 6th gen OEM Onboard Air Compressor (Tire Inflator) install complete using how-to DIY Screenshot 2026-03-18 at 2.35.58 PM
gydooya
Eddie
Dallas
6gen TRD ORP
New question: Does anyone have access to the wiring diagram? I’m trying to figure out the compressor control panel connector harness. My TRD ORP is missing the connector on the harness and I was curious to see if just a cable I’m missing or something more.
abstraakt
abstraakt
Lakewood, CA
2025 TRD ORP Hybrid / Ice Cap
Did you by chance see the YT vid talking about modifying the wiring on the control panel to tap into existing sources? That might be able to help you out.
gydooya
Eddie
Dallas
6gen TRD ORP
Yes, but since I have the non hybrid TRD ORP my wiring harness is different than both the SR5 and the Hybrid in the YT videos. So I was wondering if I would just need a connector cable or I would have to run the power cable like they did in the SR5 video but that causes another issue as I don’t have a 12v outlet to tap into I have a 120v 400w plug… hence the different harness
pmedicj
MA
Parts arrived from ELMHURST McGrath and I’m getting ready to tackle this install on my TRD Pro. Looks pretty self explanatory from the video and pics posted. It’s a well thought out kit for sure. Even has its own replaceable air filter.
