- Joined
- Mar 3, 2026
- Threads
- 2
- Messages
- 44
- Reaction score
- 10
- Location
- California
- Vehicle(s)
- Offroad Premium
Wanted to see if you had figured this out. I’m looking at the Viofo dash cams but want to make sure parking mode is possible and what the installation entailsI picked up my ‘25 TRD Pro a month ago and did a lot of research on dash cams. It was one of the first accessories I wanted to purchase since I’m on the road a lot and often park it outside.
Ultimately, I chose the VIOFO A329S with the 3 channel set up and the HK6 hardwire kit. The cameras look great and worked flawlessly for about 2 weeks. Then, it wasn’t booting up anymore. I reached out to VIOFO and they sent me a new hardwire kit. After checking fuses and connections, measuring Voltage/Amps etc it appears the regulator piece may have failed. I actually received the replacement today but have not had time to replace it. In the meantime, it works with the car adapter (unfortunately this means there’s no parking mode which was the selling point for me). I will update once I have it installed.
I don’t know if I can recommend the hardwire kit, as the other battery powered option mentioned above might be more convenient. If you chose this route I spent a lot of time checking fuses. The best options I found were:
RED (constant power) - HAZ (fuse for hazards)
YELLOW (ACC) - P/Outlet No. 1
Ground - Screw/Bolt
Unfortunately, the mini low profile fuses still protrude out too far so that you certainly won’t be able to put the fuse box panel back on, but you also won’t be able to completely snap the kick panel back in place. I can only snap 1/4 back on to hold it there. No issues with it falling off or anything yet but there’s going to be a little vibration under there.
Running the wires to the rear and dash weren’t too difficult. It’s a tight fit over the airbags in the door to the front dash, but doable with some finesse and patience.
Again, really nice camera images and everything. But disappointed in the ongoing issue with power from the hardwire kit.
