Interior Lights- Map / Dome
tpmacleod
Tim
Vancouver, BC
2026 TRD Pro / 2014 Limited
Has anyone swapped out the interior lights. The 6th Gen are worse than the 5th. In my 5th Gen I used the MESO Custom which were an easy install. The 6th Gen version says you need to drill. I couldn’t find anymore information on that. What are people doing?
retiredlifeat39
Bryan
michigan
MESO what I did, easy install with little patience on map lights.
tpmacleod
tpmacleod
Tim
Vancouver, BC
Thanks. It mentioned drilling on the webpage? Is that correct? Also, what is all that extra wiring for the map lights? Do
2025 2026 4runner 6th gen Interior Lights- Map / Dome IMG_4265
2025 2026 4runner 6th gen Interior Lights- Map / Dome IMG_4266
retiredlifeat39
Bryan
michigan
That is correct and 4 holes would be required. Although, there is a video out there of a guy who disconnected them and wired them from the same factory holes. This involves taking the led off the wire lines. Not a huge inconvenience but depends on your skill set on working with electric
retiredlifeat39
Bryan
michigan
Extra wiring is everything you need to connect them up to the OEM hardware. There isn’t anything extra per say you’ll use it all
Henry
Henry
CT
Here's some good installed threads (with DIY instructions, photos, review) of the MESO custom map lights:
https://www.4runner6g.com/forum/thr...-dome-map-light-upgrade-white-red-modes.5897/
https://www.4runner6g.com/forum/threads/meso-custom-lights-installed.8404/
https://www.4runner6g.com/forum/threads/meso-customs-map-lights-dome-light-installed.6063/
mfoga
r4unner
Found this the other day and it worked.
https://a.co/d/03q5tq9B
Simple as the meso but used the stock cover still. It has control board to allow button to still work as before and led board. May not be as bright as meso but way brighter than stock and looks stock.
I wish they had a similar thing for the map lights.
2025 2026 4runner 6th gen Interior Lights- Map / Dome PXL_20260325_005932109
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
Nice!
Did you get the 1280 or 720 lumen ?
Just installed the 1280 version, it's day now and it's bright, I'll see how bright after night fall.
