What's the weight of the RV trailer you tow?
My4Runner4fun
Jim
Washington
Toyota Highlander Sport
We are interested in towing an Intech Sol Eclipse RV trailer with a 2025 4Runner Offroad Premium. (Non-Hybrid) The esimated trailer weight with gear, and water/propane full will be about 4,300 pounds. The tongue weight is 540 pounds. We want to know if members tow a similar size trailer, and your experience with the 6th Gen 4Runner? Especially on mountain passes and under windy conditons. We would use a weight distribution hitch and trailer brake controler. Thank you,
Jim
I wouldn’t pull anything that is over 4,800lbs. What you’re pulling is definitely fine.
Vincenzo
Southeast
I pull 4,000 pounds. Tongue weight is right on at 400#. Boat, motor, trailer on flat with no issues. RVs pose other issues. Height being one of them. My buddy tows a travel trailer with a 5th gen within spec and it’s a chore. Height causing drag while towing and passing semis made him almost crash one time. Sway control and slower speed is your friend.
PierceVonCloud
Tim
South Dakota
2025 Hybrid OR
I tow a Sol Horizon with my 2025 Off Road Hybrid. Got the 6G specifically for towing the camper because as much as I loved it, my 5G Off Road was a wheezer when it came to towing. The weight of the Horizon is very close to your Eclipse and my 2025 tows it effortlessly. I know I have the hybrid, but I joke that my 6G can accelerate with the camper better than the 5G did empty. I've seen non-hybrids towing campers right at 5,000 pounds. Even the non-hybrid torque curve destroys a 5G 6 cylinder. You'll be fine. 5G owners who scoff at the 4 cylinder engine have no idea how to read a torque curve. Not to mention the 8 speed transmission versus the old 5 speed. Again, not even close when it comes to towing.
As far as stability, I also use a weight distribution hitch. The 6G handles head wind just fine, but your mileage will drop below 10 mpg. The 5G did handle side winds better for some reason. My 6G tramlines highway grooves more and is not as rock steady with side winds. It could be my non-OEM tires or the stiff 6G suspension (that's a whole 'nother discussion).
My4Runner4fun
Jim
Washington
Hello, and thank you for your insightful reply. It's really nice to hear the experience from someone who is also towing an Intech Sol trailer. I liked your vote of confidence in the non-hybrid, too.
Jim
GetOut
Steve
OhiO
I tow an Airstream Basecamp 20X, which is around the same weight and hitch weight as the Sol Eclipse. My 2025 Non-hybrid SR5 pulls up steep hills, and can even accelerates up them, with ease. Very stable too, as long as you have a weight distribution hitch. White knuckle experience without it! I get between 13.5-14.5 mpg as long as I keep to the speed limit.
My4Runner4fun
Jim
Washington
Thank you, this is the type of feedback I'm looking for.
My4Runner4fun
Jim
Washington
Jim
I wanted to follow-up and see if there were any other 6th generation 4Runner owners who are towing an RV travel trailer, that are in the weight range of 4,300 to 4,500 pounds loaded. We are also considering the Intech Sol Dusk model that has a tongue weight of 540 to 575 pounds. Is that tongue weight too close to the 10% rule for the 6,000 pound towing capacity of the Offroad Premium Gas?
My4Runner4fun
Jim
Washington
That's helpful information, thank you.
Jim
PNBC4Run
PNBC
2026 4Runner TRD Sport
2026 4Runner 6g TRD Sport. We are towing an Airstream Caravel 16rb, about 4300 lbs fully loaded. Blue Ox sway bars and weight distribution hitch make it pretty easy. We get 19mpg at sea level. Also pretty important to regularly check your trailer's tire pressure. Low tire pressure on the trailer can be a safety issue.
One thing I haven't tried out yet on the 6G is the "trailer path assist" when backing in to campsites. This week!
Blue Hen 13
Pittsburgh, PA
4Runner ORP
We tow a 2017 19’ Airstream Flying Cloud which I believe is GVWR of 4750. We haven’t had it ever loaded to that but the 6G has no issues with it and can still accelerate without issue. Not trying to floor it but the power is there if needed. Haven’t had an issue up or downhill but the few trips without a WD hitch I second the white knuckle experience. We use an equalizer WD hitch and an aftermarket trailer break controller as we didn’t have the tow package option.
My4Runner4fun
Jim
Washington
Thank you, that's helpful feedback.
My4Runner4fun
Jim
Washington
Perfect, this is helpful information.
pmedicj
MA
Glad to hear this! We are still waiting on our TRD pro to come in that includes the tow tech package and brake controller and intend to tow our flagstaff e-pro 20bhs
I was looking at weight distribution hitches and was going to order the equalizer also. Which size did you go with and any tips on the setup of it?
