Installed - FitCamX 4K Integrated Dash Cam (Tacoma Model)
Jpr18
Jpr18
Southern California
ugh the Mangoal stuff is 100% garbage. They aren't CE/UL compliant, not to mention they literally cloned my entire product line and work. If you're interested, I have a quick reference chart showing 4 different power options for your T4R, none of which require accessing the fusebox :cool: . Check it out here: https://www.4runner6g.com/forum/threads/dongar-technologies-6g-dashcam-power-options-now-live.3448/
Our 16-pin Toyota SKU uses actual TE connectors and terminals (same source as OEM!) and our USB module has true 5/9/12V USB-C compliant output, designed 100% in-house (mangoal uses an off the shelf 5V module). I had to pony up a ton of money to get liability insurance and do real testing on adapters that plug into the Safety Sense modules US-based companies actually have to worried about getting sued. If you want an actual decent version of the product you linked, hit me up. Or I can send you a Dongar PRO which gives you switchable parking mode options.
I would definitely prefer your version, but it was out of stock when I needed it! I need just the basic one, I don't need any switchable parking modes.
Also, can I hide everything behind the plastic shroud or do I need part of the adapter to be stuck to the windshield? I have the auto dimming rearview mirror.
Thanks
Van Solo
Van
Calgary / Canada
FitcamX Confirmed, They are already scanning the 2025 4Runner and will head into molding process then they figure 90 days. See attached email notes below.
Hello, we are sorry, we don’t know the expected date yet. We are currently 3D scanning the cover. After the scanning is completed, it will take about three months to complete the camera mold.
Best regards,
Mila
FITCAMX Support Team
get.outside.75
Brian
Charlotte
Limited iForce max
i wrote to Fitcamx today and they said the new 4runner version will be available at the end of September.
EverydayFred
Fred
Las Vegas
2025 SR5
Formidable
Bellevue, WA
2025 TRD Pro
get.outside.75
Brian
Charlotte
Limited iForce max
Nice! So is removing the overhead console unnecessary? It just plugs into the rear view camera? I don’t quite understand the review on the link. Screenshot below.
No need to remove overhead console unless you are using the specific "Sienna" cable that allows the camera to operate in parking mode. It's a super easy install (when not using the extra sienna cable). I only have the front camera, pull in when I park, garage kept and work from home, so the chance I would ever catch anything in parking mode from the front camera was slim to none.
Formidable
Bellevue, WA
2025 TRD Pro
Awesome. Just placed my order for the 4runner and wife’s MDX using the code Fred provided above FRED10
Formidable
Bellevue, WA
2025 TRD Pro
Just an update. Got the fitcamx 4k front and 1080p rear dash cams installed. Excellent OEM fitment/look. Used the link earlier for the mounting of the rear cam to take the place of the center headliner push pin.
2025 2026 4runner 6th gen Installed - FitCamX 4K Integrated Dash Cam (Tacoma Model) IMG_2790
2025 2026 4runner 6th gen Installed - FitCamX 4K Integrated Dash Cam (Tacoma Model) IMG_2787
2025 2026 4runner 6th gen Installed - FitCamX 4K Integrated Dash Cam (Tacoma Model) IMG_2786
2025 2026 4runner 6th gen Installed - FitCamX 4K Integrated Dash Cam (Tacoma Model) IMG_2785
BonRunner
2026 TRD Sport Premium / WCP
I advise this tip to many owners about the rear cam.. Move it to the passenger's side mounting point, not center.
When your rear glass is dirty, the wiper won't clean that center spot & your cam won't see anything either.
Example ⬇
2025 2026 4runner 6th gen Installed - FitCamX 4K Integrated Dash Cam (Tacoma Model) FB_IMG_1770101661805
Formidable
Bellevue, WA
2025 TRD Pro
Example ⬇
Good tip!
