bt75cj5
bt75cj5
Bob
Washington
2025 Toyota 4runner, 2021 Jeep Gladiator
Can they not just run cables to the jump area in the engine bay? I heard you can install a switch hookup to that instead of having to run all the way back to battery.
I'd have to check with Warn's R&D, but my understanding is that they go all the way back to the battery for the winch draw protection... I'll get back to you once I get confirmation.
jpa2002
Jon
Daleville, VA
2026 TRD Pro 4runner
It would be nice if they offered a wiring kit with a switchable relay for the hybrid models.
bt75cj5
bt75cj5
Bob
Washington
I'll be happy to pass your request to Warn... Thanks
jpa2002
Jon
Daleville, VA
That would be great. Can you also get a copy of the installation instructions for the bumper?
Jon
bt75cj5
bt75cj5
Bob
Washington
I'll get a copy and share it with you !! Thanks..
bt75cj5
bt75cj5
Bob
Washington
Apparently the file is too big to post... if you can send me an email address, I'll gladly send the file over..
Thank you !!
NWRes
NW WA
How did the mount work with the OEM skid plates or are you running another? I put the TRD aftermarket plate on mind and am wondering if that will work with the Warn mount.
bt75cj5
bt75cj5
Bob
Washington
I kept the OE skid plate and there was no issues with the installation...
I would presume the aftermarket one should work cause you are using the same mounting points..
Attached is a pic of my Trailhunter OE skid plate . Hope this helps..
2025 2026 4runner 6th gen WARN Semi-Hidden Winch kit for 2025+ 4Rrunner 6th gen! NOW AVAILABLE  !! 20260219_085702
