Gasoline fumes while driving and after driving - 2025 4Runner TRD Pro
MartyMcFly
Curious if you all have noticed a drop in mpg since this started?
ElonMuk
Keith
Phoenix, AZ
2025 Toyota 4Runner TRD Off-Road i-Force Max
Has Toyota completed a "smoke machine" test? Usually that's what I would do when I'd have a vehicle come in with an issue that was fuel and evap related that was harder to visibly see.
ScoMay
Tennessee
2022 Ram 1500 Rebel
OP - Wondering if the dealer did the UV test as 127.0.0.1 suggested. If they didn’t, ask them why not.
Also wondering the same regarding the ā€œsmoke testā€.
I feel like dealerships aren’t as committed to finding a solution as the owner is. They run one test (EVAP) and when the results show no problem they assume there is nothing wrong? Which would make me wonder if they smelled the gasoline when they had your 4Runner in the shop!
Take it back to them (or another dealership) and suggest that they run the above 2 tests. Seems like they need some prodding.
bakutheleo
2025 4Runner i-Force Max
Yeah, I think this is a major concern! I have not noticed a problem, but my vehicle is outside all the time (garage is my workshop). I have not smelled it whie driving. I see you are in Denver...is it cold outside (yeah, I know) but much warmer in the garage? It is possible that, with enough temperature differential, that the fuel in the tank would warm up and expand enough to let a bit vent out of the pressure relief. But that should not happen while driving--at least you would not smell it inside the cabin. Just a thought, but as others have said do not let the dealer pass this off. As you know this can be a safety and health issue.
JohnnyMTB
JohnnyMTB
Denver, Colorado
Interesting hypothesis on the warmer garage and things expanding. I would buy that if it was a long time before I smelled the smell but give it an hour after I get home and it's pretty bad. Not to mention smelling it while driving makes me think something else is going on.
JohnnyMTB
JohnnyMTB
Denver, Colorado
Yes I agree.. I don't know if they did the UV test as I don't recall them stating that and don't see it on the paperwork right now I'm waiting for Toyota corporate to get back to me to give me next steps.
JohnnyMTB
JohnnyMTB
Denver, Colorado
I'm not even sure what a smoke machine test is but they did not mention anything about conducting one of those
ScoMay
Tennessee
2022 Ram 1500 Rebel
Did you find out if the techs at the dealership were able to smell any gasoline odor? If they did, and they returned it to you with nothing else but the negative test result (on VAC test) done, then I would DEFINITELY NOT return to them for any further help.
Hopefully Toyota corporate can give you some constructive direction toward a solution.
JohnnyMTB
JohnnyMTB
Denver, Colorado
They said they could not replicate the issue. My guess is because in the service department there are thousands of vehicles coming through all the time and the place smells like a giant exhaust factory. It would be hard to place any kind of smells coming from one specific vehicle in a situation like that.
Lamuncha
don
new england
2025 4 runner
Not sure if this could be related but In Nov this year with 1500 or so miles on the truck I heard this whirring sound coming from the drivers side near the rear wheel. Loud enough to hear 15 or more feet away.
Sounded like a miniature air compressor.
All ignition etc off. Not sure how long it had been whirring before I noticed it.
Before climbing under it in 4 inches of slush I called a dealer.
They told me it was normal and part of a self test those things go through. As I recall I believe he told me it was part of a self test of the EVAP system.
They also mentioned that was why the gen 6 batteries were going flat.....
I cannot recall a bunch of battery problems here so that may be chat.
I would keep it outside especially with this small motor randomly starting a test.
no reason to smoke test evap if there are no codes...system is intelligent and
knows front to back if there are leaks or not. very rare for evap to have any leak w/o
ECU throwing a MIL
I'd be checkin high pressure fuel pump and rail
Tarekith
Upper Left US
4Runner ORP & ā€˜22 Tacoma OR
Have you ticket it into the dealership and have they done anything about it?
No, unless I can replicate issues 100% of the time in a way that the stupidest person in world can understand my dealership won't do anything about it. They are next to worthless for troubleshooting unfortunately, while also being the only Toyota dealership within 3 hours of me.
JohnnyMTB
JohnnyMTB
Denver, Colorado
Sorry to hear that! 😭
JohnnyMTB
JohnnyMTB
Denver, Colorado
ECU throwing a MIL
šŸ‘šŸ‘šŸ‘
